KMC Wheels 1 - Top
Barrett - Top
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 34
  1. #11
    The "anti-yuppie" Sharp Shooter's Avatar
    Join Date
    Oct 2007
    Location
    the trailer
    Posts
    3,818
    Thanks
    720
    Thanked 1,118 Times
    I ran a forward alternator using a pulley that was drilled to mate up to the PTO (I didn't run a dampner). The best set up I've seen was Larry Hamiltons flywheel pulley set up off the back of his superstock. PM mxboogieman on PB and I'm sure he will hook you up the info for that. He didn't run a bellhousing so you could see everything.
    Quote Originally Posted by RiverDave View Post
    I can tell you that I go a period of time and literally start acting like a tweaker.
    My YouTube channel--------------V-Drive Video Productions-------------Facebook
  2. #12
    Senior Member CampbellCarl's Avatar
    Join Date
    Jan 2008
    Location
    Whittier Ca & Katherine's Landing AZ
    Posts
    12,831
    Thanks
    173
    Thanked 5,720 Times
    So in the rear of the boat, fuel cell gonna sit there on top of the strut? Seems like (echo Barry) you could use some sort of direct drive setup that is normally seen on the other end of the crank. Bolt up something to the crankshaft and direct drive it.
    Life was simpler when I was a dick..
  3. #13
    Senior Member
    Join Date
    Oct 2010
    Location
    Huntington Beach, CA
    Posts
    5,177
    Thanks
    52
    Thanked 1,490 Times
    Quote Originally Posted by CampbellCarl View Post
    That requires a special alternator correct? Spinning it at ditect driven high rpm for any amount of time will eat up a regular alternator. I used to blow alternators like crazy in my mustang after changing pullies until I realized the alternator was spinning at almost twice the normal speed.Thank jeebus for aauto zone lifetime warranties!
  4. #14
    Senior Member Outdrive1's Avatar
    Join Date
    Dec 2007
    Posts
    23,947
    Thanks
    2,104
    Thanked 7,428 Times
    Quote Originally Posted by ka0tyk View Post
    It would only depend on pulley sizes, alternators already spin off the crank normally. Rear mounting it on the bell housing side would make no difference.
    Quote Originally Posted by River911 View Post
    And this POS Hyundai sucks ass juice through a paper straw
    I feel like a fucking fag driving this thing.
  5. #15
    Senior Member
    Join Date
    Oct 2010
    Location
    Posts
    5,177
    Thanks
    52
    Thanked 1,490 Times
    Quote Originally Posted by Outdrive1 View Post
    No no... a direct drive setup off the rear.
  6. #16
    Join Date
    Dec 2007
    Posts
    23,947
    Thanks
    2,104
    Thanked 7,428 Times
    Wouldn't matter, crank turns the same whether you use the front or the rear. It's turning at the same rpm.
  7. #17
    Engine building character obnoxious001's Avatar
    Join Date
    Dec 2007
    Posts
    4,352
    Thanks
    5
    Thanked 829 Times
    That would be pretty cool actually,, probably a modified Rex setup, or copy if they don't have one in stock. Rear mount direct drive would actually run the alternator the same direction as the crank (and thus the "normal" rotation), but I have not heard of guys with the regular off the damper direct drive having alternator failures. I had one on my Vega, didn't really drive the car enough to see if the one to one ratio was enough to keep the battery charged in street use, but in a boat that turns easily twice the normal rpm of a street vehicle, it makes all kinds of sense.
  8. #18
    Senior Member westair's Avatar
    Join Date
    Sep 2007
    Location
    Oceanside/LHC
    Posts
    3,064
    Thanks
    751
    Thanked 570 Times
    Direct ... your referring to a setup like this? this would be ideal, Barry your thinkin Rex might have something? nothing else going back there except a battery or 2 .... using side fuel tanks for now.
    SS thanks for the referral, I'll send a PM ... yes something off the flywheel I think is my preference now.
  9. #19
    Join Date
    Jan 2008
    Location
    Posts
    12,831
    Thanks
    173
    Thanked 5,720 Times
    Quote Originally Posted by westair View Post
    Yeah, that's what I was thinking. The boat in the pic belongs to Phil (DiMarco21 on the boards), send him a note to see if he made his stuff (probably did, he's a talented fucker) or modified a Rex or somebody else's deal.
  10. #20
    Join Date
    Dec 2007
    Posts
    23,947
    Thanks
    2,104
    Thanked 7,428 Times
    Clearly not what I was envisioning. That's cool.
    I was thinking of a pulley on the flywheel with some kind of custom mount. Maybe even reverse mounted like mine is.
