20 foot Schiada 20SS v-drive. it is a smaller version of the 21 or 22 River Cruiser. this is considered the Ferrari of this type of boat. I have gone thru this boat and it is basically Brand new inside.. this is a Simple interior in it since I wanted to Keep weight down .. this boat was completely gone thru and everything was either Brand New or polished or powder coated all in December of 2013.. I have about 28-30K into the hull . Engine not included which is a 548 Blown E-85 deal making about 1200 hp. ive ran this boat right at 100 mph multiple times. things I upgraded in boat was the Propshaft to a 1 1/8th aquamet22 shaft with a Brand new Stainless V-Bottom Strut from Bergeron marine, Kindsvater 11 1/8x16 2 blade prop cut down to work on this boat.
Also had Bergeron build me a dual cable rack n pinion steering and a 8 inch stand off on steering column and a Billet steering wheel 1/2 leather wrap. V-Drive is polished and has a set of 40 gears in it.. also has upgraded Shaft log seal Bergeron sells.. Rear cavitation plates on boat are also Made of Stainless steel and I had them polished to a Mirror finish.. when I built this boat I didn't hold back on spending money to build it.. All new gauges and compete new re -wire job. Engine oil cooler, Trans cooler, TH400 Trans built to handle Massive powered , Down pedal with lockout handle.. I Also have a Driveline tube cover for it just needs to be installed. I could name things ive done all day . this is a Sold boat you wont find a floor or string in another boat any better then this one.. Very excellent shape hull.. asking 16,500K .. 530-333-1047 Bill
Here is a Build thread me and my buddy did on the boat...
http://www.performanceboats.com/v-drives/174873-schiada-20ss-build.html
