Positive Trim - Top
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
  1. #21
    Senior Member Ballsdeep's Avatar
    Join Date
    Feb 2009
    Posts
    3,129
    Thanks
    1,160
    Thanked 1,407 Times
    Quote Originally Posted by pipemn View Post
    My wife manx matching your description and it drives fine on streetAttachment 523085Attachment 523086Attachment 523087Attachment 523088
    091 box, 2332motor,it does have tube frame mated to pan.
    Whatever happened to your Dejong?
  2. #22
    Senior Member RaceTec's Avatar
    Join Date
    Mar 2011
    Location
    Huntington Beach, CA
    Posts
    1,141
    Thanks
    412
    Thanked 172 Times
    Quote Originally Posted by wsuwrhr View Post
    Unless you are planning on a hydraulic clutch, check the bowden tube for the clutch cable to make sure it is attached and in good shape while your pan is torn down that far.
    Replace the fuel line with at least a 3/8 ID tube.
    Brian
    Thanks Brian!
    I am sure I will be picking your brain more as this project progresses!
  3. The Following User Says Thank You to RaceTec For This Useful Post:
    wsuwrhr (11-30-2016)
  4. #23
    Senior Member manxman's Avatar
    Join Date
    Mar 2010
    Location
    san marcos
    Posts
    184
    Thanks
    Thanked 15 Times
    sweet!!! That is a cool color!!
  5. #24
    Join Date
    Mar 2011
    Location
    Posts
    1,141
    Thanks
    412
    Thanked 172 Times
    New bowden tube and new fuel line, basically everything is going to be new but the tunnel...
    Issac is doing all of the ground work for me, then it will be my turn to get crazy fabricating and building the rest...
    I will go with hydraulic when I swap out the trans and stuff in the future...
  6. The Following User Says Thank You to RaceTec For This Useful Post:
  7. #25
    The Masheenest wsuwrhr's Avatar
    Join Date
    Dec 2007
    Location
    Sunny So Cal
    Posts
    25,305
    Thanks
    69,534
    Thanked 13,897 Times
    Quote Originally Posted by RaceTec View Post
    Nice.
    Good man.
    See all the things I learned the hard way, you get for free.
    Cheap, fast, good, pick any two.
    Quote Originally Posted by milkmoney View Post
    Huh?
    Quote Originally Posted by HavasuHank View Post
    I'll put it into easy to understand lingo - I'm going to go make a shitload of money
    See SB Products @ http://www.sbp2020.com
    View and "Like" SB Products on FB
  8. The Following User Says Thank You to wsuwrhr For This Useful Post:
    RaceTec (12-01-2016)
  9. #26
    Senior Member UltraLucky's Avatar
    Join Date
    Oct 2007
    Posts
    348
    Thanks
    107
    Thanked 215 Times
    Brian
    And the shift rod bushing, those are a pain to try to replace when it is all together.
  10. The Following 2 Users Say Thank You to UltraLucky For This Useful Post:
    RaceTec (12-01-2016), wsuwrhr (04-24-2017)
  11. #27
    Join Date
    Dec 2007
    Location
    Sunny So Cal
    Posts
    25,305
    Thanks
    69,534
    Quote Originally Posted by UltraLucky View Post
    easy job.
    But certainly that too. I figured that one went unsaid, the others, no one thinks of sometimes.
    Huh?
  12. #28
    Senior Member
    Join Date
    May 2012
    Location
    lake havasu city,mission bay
    Posts
    125
    Thanks
    20
    Thanked 43 Times
    Quote Originally Posted by Ballsdeep View Post
    Still have it,going to put it up for sale again when I get some spare time.Got to many projects going as usual.
  13. The Following User Says Thank You to pipemn For This Useful Post:
    Ballsdeep (03-03-2017)
  14. #29
    SlumLord Ziggy's Avatar
    Join Date
    Sep 2007
    Location
    Oceanside Ca.-Lake Havasu City Az.
    Posts
    20,027
    Thanks
    3,931
    Thanked 9,100 Times
    My FRP is in the final stages of its build. 2.5turbo subie. Mine is the mid-travel body, deeper and wider body than Scotts full length body.
    I did beam front end since I'll be using it more on street than offroad. With A-arms you get a lot of body roll in turns.
    Started project in 2011 but sat for 5 years due to other priorities.
Size:  47.1 KBName:  uploadfromtaptalk1488570324575.jpg
Size:  59.6 KBName:  uploadfromtaptalk1488570360349.jpg
  15. The Following 5 Users Say Thank You to Ziggy For This Useful Post:
    BUDMAN (03-03-2017), Cole Trickle (03-03-2017), Dan Lorenze (04-24-2017), OutCole'd (03-03-2017), wsuwrhr (04-24-2017)
  16. #30
    Join Date
    Sep 2007
    Location
    Posts
    20,027
    Thanks
    3,931
    Thanked 9,100 Times
    Body just got gelled... Manxman make sure this one is good and strong!
    Pan is starting to come together, new halves are in...
    Attachment 524682Attachment 524683
    I believe I saw that body last time I stopped by at frp...or at least I saw another blue one like that.
  17. The Following User Says Thank You to Ziggy For This Useful Post:
