Interceptor - Top
R&B Auto - Top
Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 38 of 38
  1. #31
    HAVASU BOUND BUDMAN's Avatar
    Join Date
    Jul 2011
    Location
    Corona, Ca.
    Posts
    6,137
    Thanks
    4,614
    Thanked 4,169 Times
    Quote Originally Posted by Ziggy View Post
    My FRP is in the final stages of its build. 2.5turbo subie. Mine is the mid-travel body, deeper and wider body than Scotts full length body.
    I did beam front end since I'll be using it more on street than offroad. With A-arms you get a lot of body roll in turns.
    Started project in 2011 but sat for 5 years due to other priorities.
    Attachment 543550Attachment 543551Attachment 543552
    Coming together nicely Zig. When the anticipated finish date?
    WWW.PREMIERTRAILERSERVICE.COM
    Life is too short not to have a good time....
  2. #32
    SlumLord Ziggy's Avatar
    Join Date
    Sep 2007
    Location
    Oceanside Ca.-Lake Havasu City Az.
    Posts
    20,028
    Thanks
    3,931
    Thanked 9,100 Times
    Quote Originally Posted by BUDMAN View Post
    What I hope is a few weeks will more likely be a month+.
    Helped him trace a few electrical ghosts last weekend. Dash is fully done and wired now too. This weekend he's on the 3 day booze cruise to Ensenada.
    Has to modify radiator in and outlets still and a few details on engine still need to be done. Intake manifold is put on backwards to fit car right so throttle linkage and a couple other little mods are still necessary.
    Wire harness has been a huge job. Added electric power steering, heated seats
  3. #33
    Join Date
    Sep 2007
    Location
    Posts
    20,028
    Thanks
    3,931
    Thanked 9,100 Times
    Quote Originally Posted by RaceTec View Post
    I am getting a roller started and wanted your opinions on a couple things...
    Mostly street with some off-road, full length pan, 3" body lift, IRS, 1915cc to start... In the long run it will get a new trans and probably something like an ecoboost...
    1. What do you buggy guys think about 30"x 9.5" on 15" x 7" all of the way around, will it look funny? I was just thinking the 4 plus the spare being the same size would be easier?
    2. Thinking about mid travel, doing 3X3 arms and a 6" over beam with coil overs all of the way around, will that be decent for the street and a little off-road? Or should I save more and do an a-arm conversion?
    Any other suggestions?
    Drove my FRP Manx home this weekend[finally!]. Mid travel version.
  4. The Following 7 Users Say Thank You to Ziggy For This Useful Post:
    Ballsdeep (04-24-2017), BasilHayden (04-24-2017), Dan Lorenze (04-24-2017), Deja_Vu (04-24-2017), HallettBill (04-24-2017), UltraLucky (05-13-2017), wsuwrhr (04-24-2017)
  5. #34
    Senior Member RaceTec's Avatar
    Join Date
    Mar 2011
    Location
    Huntington Beach, CA
    Posts
    1,141
    Thanks
    412
    Thanked 172 Times
    The project is starting to get a little more crazy than I expected now that I am talking to people and collecting parts... So far Dave Brown 5X5 arms with 4" lift built in, front is possibly going to be a-arm. Looks like I am getting a little help from some friends like Gray Area http://www.gryarea.com/ so I will be going with their micro stub and 2" hollow spindle setup with 4 piston calipers all of the way around... Still figuring out what engine and more than likely weddle 5 speed...
  6. #35
    Senior Member Wheeler's Avatar
    Join Date
    Dec 2007
    Location
    Somewhere Arizona
    Posts
    13,533
    Thanks
    2,289
    Thanked 3,979 Times
    Great color!
  7. The Following 2 Users Say Thank You to Wheeler For This Useful Post:
    wsuwrhr (06-23-2017), Ziggy (06-23-2017)
  8. #36
    The Masheenest wsuwrhr's Avatar
    Join Date
    Dec 2007
    Location
    Sunny So Cal
    Posts
    25,339
    Thanks
    69,636
    Thanked 13,921 Times
    You do realize that is enough piston area to stop a 4000lb car effectively, right?
    You are a nut. Looks nice though.
    Cheap, fast, good, pick any two.
    Quote Originally Posted by milkmoney View Post
    Huh?
    Quote Originally Posted by HavasuHank View Post
    I'll put it into easy to understand lingo - I'm going to go make a shitload of money
    See SB Products @ http://www.sbp2020.com
    View and "Like" SB Products on FB
  9. #37
    Join Date
    Mar 2011
    Location
    Posts
    1,141
    Thanks
    412
    Thanked 172 Times
    Yeah, but I figured better go overboard with the brakes because I have a couple deals on engines floating around that will up the weight and HP significantly...
    I am currently drawing up a boxed fabricated chassis for it now that i will have laser cut and start piecing together...
  10. The Following User Says Thank You to RaceTec For This Useful Post:
  11. #38
    Join Date
    Dec 2007
    Location
    Sunny So Cal
    Posts
    25,339
    Thanks
    69,636
    Or skid its way, right into a wall.
    Front disks maybe, 4W? not a chance. 4 piston is just too much.
    Mine has 4wdrums and it will put you thru the windshield.
    Look at some curbweights of some dressed bajas before you do that.
    V8, tube chassis, long travel and huge tires all around, maybe, otherwise, I think that will be a letdown, maybe even dangerous.
    Huh?
