Gelcoater
- Sep 26, 2009
- 21,680
- 36,565
Any go to sources for electrical?
View attachment 566281 View attachment 566282
That piece of red wire on the passenger floor and the wires coming from the distributor are the only wires I can find on this car.
So an entire street legal harness build is in my future.
I'm a painter. All I know is electricity is blue. And it hurts.
I've figured out what the ground symbol is on en electrical schematic. Beyond that it's Egyptian.
Any and all advise here is appreciated.
If it is an original Manx body and Dash I would keep the configuration of the dash as close as possible if you can, The dash is one of the ways to distinguish the original bodies from the splashed molds. I had to trim mine a bit to fit around the cage. The windshield should be a flat piece of glass, no bow.
Lot of guys are using the Rebel Harness or a stock Bug harness for the year you want to replicate the lighting and turn signals from. Than you can use the VW wiring diagrams and turn signal switches and relays. I went with the 1966 so i could have the turn signal and Hi/Low beam switch on the column.
I knew that was a real Manx when I saw it.. You scored, Gelcoater.. Good job.... Our cars are very similar. I want to say that your windshield might be on backwards. The flat of the windsheild goes to the inside of the car. Hard to tell from the pics.
Dan, you have a build thread here or the Samba or somewhere?
Would love to see pics of various behind the scenes views, if you follow me.
Routing of cables, fuel lines, oil cooler, etc.
I'd like to only build this thing two or three times
Edit.
The windshield.
There's a channel pointed towards the inside of the car?
View attachment 567544 View attachment 567545
Channel should be pointed towards the front of the car. It is there to capture the front of the old style fiberglass tops.
On tops...Channel should be pointed towards the front of the car. It is there to capture the front of the old style fiberglass tops.
I'm on Samba but I didn't do a build thread. My buggy is real basic, because it's a Meyers I wanted to keep it pretty stock. The fuel line is stock and goes through the tunnel, all the wires are ran through the tube on the left side of the car and I use no external oil cooler.
Is yours a classic body? For some reason I thought you had a 2+2 body?
Fuel line through the tunnel.
There isn't a hard line that I can see in there. There are no access holes cut, and even the hole for the E brake was blocked off before what appears to be an epoxy, possibly a thin coat of bed liner was applied. It looks pretty sharp and clean. I understand running the hard line through there is a royal PITA? Even with access holes.
Worst case scenario I have to buy the kit that welds in where the access hole is cut that reinforces the tunnel. Then refinish the floor pan.
I believe within the stack of paper that came with the car are receipts for the coating used.
I have the same car as you, I believe they call it a "Classic".. Yes, i'm using the stock beetle fuel line in the tunnel, their were connections for it in there. You might have to do some light fabrication and make something work.. But, my brake line is routed on the inside of the car next to the tunnel, a common route. All the wiring is ran through the glassed in vacuum hose on the left side of the car.
The front access is thru a plate bolted on the front of the chassis where the front end bolts on, and the rear access is where the trans nose comes into the car.
Anything with a big motor should have at least a 3/8 fuel line.
Running a fuel line through the tunnel is easy peasy. You also need to check the Bowden tube at the rear to make sure it isn't broke.
What goes down the hose on the other side? This car has them down both sides?
The brake line, what of it that is there is run how you describe yours. There's a line lock in line around the shifter area.
From there forward it needs everything but the master and brake switch.
Hard lines out back need some love but I think are usable.
Should there be some sort of cap or cover for the front of the tunnel?
Looking deeper at the ass end, it needs bump stop mounts and snubbers.
Complete Volkswagon noob.
This is the cover plate at the front of the tunnel. View attachment 568514
Yep, that is the one.
Reinforced Emergency Brake at tunnel, very common area for the tunnel to get stress cracks. View attachment 568516
Snubber goes over the top of the torsion arm. this is an old picture but you can see it
Wow, wild, no holes for bolts either. I wonder if your frame horn in the front has been replaced. The hole in front of all the bugs I worked on was way bigger that that.
FYI, that hole needs to be closed up with a cover of some type....
But the cover isn't structural at all, is it?
Acceptable to fab a light weight fiberglass (or carbon fiber :cool ) plate and rivet it on?
Now I see why you said it would be a pain to run a tube thru for a fuel line.
Right?
Not sure what to do?
Needs to be secured in there some how?
The idea of running fuel line down one of the body tubes doesn't appeal at all.
Mine is not in a sense, it is not that long of a run, and it is "contained."
I used regular coiled alum fuel line, and it inside a regular rubber hose inside the tunnel for abrasion. The tube is initially secured to the Holley blue pump with a tube nut, the pump is secured to the "pan" under the fuel tank. Been that way for 20 years.
Brian
That might be the route.
Getting the hole cut with a plasma will be an event.
I don't think I have a power outlet that would support one, so the car would have to go to the cutter. Rent a trailer, arrange an appointment, etc, will end up being a couple hundred bucks and half a days effort.
To cut a hole bigger.
How do plan on using the car once its back together? Street and mild trails or something requiring a little more travel?
The reason I ask is the top part off that tunnel below the gas tank usually needs to be clearanced for the tie rods if you are using the stock steering box.
Might be able to accomplish two issues at once.
Do these cars need a coil shock out back?
I was thinking 4 white KYBs ?
