PBC - Top
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Junior Member
    Join Date
    May 2011
    Posts
    8
    Thanks
    Evac or puke tank???
    I have a 496 stroker in my baker that's roughly 575hp. motor has been great except the valves on passenger side needs adjusting as they are fresh with only one trip. The right valve cover " looking at rear of motor forward" has a PVC valve at the rear the vents to carb and left valve cover has a billet breather at the front. My headers are water jacketed with a ball valve I manually control. I noticed that during hard runs above 5200 rpm I was getting some water and oil coming from the breather. The motor is fresh and should be good but I can't have an oily mess on my boat so I was going to add a puke tank or now I have read about the evac system and was wondering what you guys might recommend? Could I also been sending too much water to the headers? I'm looking for the best and cleanest setup possible. Thanks for the help!
  2. #2
    Senior Member nganga's Avatar
    Join Date
    Oct 2010
    Location
    Peoria AZ, Gateway to Lake Pleasant
    Posts
    790
    Thanks
    I had similar problems, I had blow by hoses running into my air intake to digest any blow by into the engine. When I put same engine in Jet boat, I added a nice eddie marine puke tank. It seems to keep it a bunch cleaner. I will try and post a photo tonight.
    As far as the water? Are you running your PVC valve into your exhaust?
    Steve
    Quote Originally Posted by MissB View Post
    What is a yote?
  3. #3
    Senior Member jetboatperformance's Avatar
    Join Date
    Dec 2007
    Location
    Atascadero ca
    Posts
    727
    Thanks
    Pan Vacs , from your crankcase to breather or a breather (puke) tank will help control the mess you describe however beyond a bit of residue there really shouldn't be a mess, several circumstances as you may know could contribute to the blow by your describing such as already inadequate crankcase ventilation (small breathers etc) or other issues also I would look at your oil temps (too low) respective the moisture you descibe beyond a bit of vapor you should'nt have water coming from your crankcase at all , Tanks like you describe are available as well as Evac fittings and breather Let us know if we can help Tom
    Jet Boat Services, parts and accessories, Unmatched Customer Service & Tech help, Satisfaction guaranteed! 805 466 4719
    www.jetboatperformance.com
    www.jetboatperformance.biz
    www.jetdriveconversion.com
    www.aggressorjets.com
  4. #4
    Junior Member
    Join Date
    May 2011
    Posts
    8
    Thanks
    My PVC valve is vented to the intake manifold. Thanks for the input Tom. My oil temp might have been cold I'm running a thermostat but temps didn't get above 130. I only have water and oil above 5500rpm. It's not much but its there. I noticed the water when I had a good fog coming out the headers. When it was a very light mist I didn't see any water. I'm thinking I might try a taller breather first.
  5. #5
    Join Date
    Dec 2007
    Location
    Atascadero ca
    Posts
    727
    Thanks
    Quote Originally Posted by Dezertracer812 View Post
    Just a thought , invest in an IR electronic Temp tester , and shoot the side of your oil pan during testing , to effectively "boil" or dissapate naturally occuring moisture in your crankcase (and oil) takes a moderate amount of engine temp Tom
  6. #6
    Junior Member
    Join Date
    May 2011
    Posts
    8
    Thanks
    I will put it in the boat and get a reading. Thanks for the input.
  7. #7
    Junior Member SNiC Jet's Avatar
    Join Date
    Nov 2011
    Location
    Sweet Home Alabama
    Posts
    8
    Thanks
    3
    Quote Originally Posted by jetboatperformance View Post
    Tom;
    What temp range would you consider adequate?
    Randy
  8. #8
    Join Date
    Dec 2007
    Location
    Atascadero ca
    Posts
    727
    Thanks
    ideally it will hover around 210 , to avoid moisture / contaminents, , no an easy task in a Jet boat and admittedly not always obtainable
  9. #9
    Join Date
    Nov 2011
    Location
    Sweet Home Alabama
    Posts
    8
    Thanks
    3
    Thx Tom....
  10. #10
    Banned RiverDave's Avatar
    Join Date
    Sep 2007
    Location
    Lake Havasu City / Parker AZ
    Posts
    44,464
    Thanks
    Question
    Tom spend a minute and educate me here for a second if for nothing else a bit of knowledge gained and the sake of conversation..
    Water comes in out of the pump to feed the motor.. I have seen guys that have these ball valve looking deals to adjust how much goes into the motor, and maybe exhaust?
    I'm not understanding why if they have a constant flow of water at some variable pressure.. They don't use something like a pressure regulator to an orifice size for the headers, and a straight up industrial wax pill style thermostat for the engine temp? If it's below X degrees the motor doesn't get any water until it goes above X degrees..
    I have read a lot of threads about these kind of issues in the past, and am just wondering why is it always a problem? There are thermostats, regulators etc.. I would assume in the automotive world / boat world already.. but if not there I know there's 100's of them in the industrial world that would fit the bill easily and not break the bank.
    BE NICE OR LEAVE
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
