21' Warlock project...
ka0tyk
first tack coat
second and third
Looking good! Who's products did you use? Give us the skinny Yo! :D
ka0tyk
well it aint perfect but it'll do for now...
onto the inside!
ka0tyk
oh and i shouldve known better than to ask the wife to pick up anything for the boat... i needed another roll of fine line tape. the place is next to her work so she calls me up and is like "THIS TAPE COSTS $26?!?!" haha
lenmann
a
Wow! The change in color completely changes the personality of the boat. It looks great!
Really though, stop holding out on the info about the product! Is it paint, gel, crayons, photoshop, what?
ka0tyk
I used interlux bright side polyurethane. Light blue and grey. Three coats each. Lots of taping! Scuffed with 320 wiped with their reducer/solvent and sprayed away. Out of the gun it looks horrible but with the reducer it lays flat. So much that their recommended application is rolled and tipped with a brush. I ended up shooting it out of a hvlp gun though.
ka0tyk
just starting to put things together....
dash stuff
putting rubrail back on, lots of rivets!
removing purple anodizing
all clean!
one thing though you can see all the stainless bolts that broke off removing the deck hardware. stainless into aluminum with years of corosion doesnt mix. gonna try the old trick of boiling the parts in water to remove the corosion and then try drilling and extracting them. might have to just drill them out completely and retap... sigh.
all hardware will be white
lots and lots of stainless
ka0tyk
tonights final progress... quite a lot got done this weekend, super excited.
put the switch panels in... marine switches are on their way.
covered the bilge in what little i had left of bilgekote. ill need to grab another can and do 2 more full coats and it'll look like new back there. the rest that got taped off will all be covered in carpet.
UltraLucky
Good call on the color change, really updates the look.
ka0tyk
went with grey on the 2nd coat of bilgekote that way i didnt have my OCD kick in cleaning the bilge every 2 seconds. started laying carpet in and glueing it down.
Looking good!!! Somebody is working like an Energizer bunny! :D
spectra3279
Vaginamoney broke
Is bilge coat thick enough to fill in the woven roving weave on the inside of my bilge? Want to get it smooth so it's easier to clean
ka0tyk
its def thick, but i dont think it will completely fill it in. just do a skim coat of some body filler and sand it smooth?
spectra3279
Vaginamoney broke
I had thought about that but am hesitant of it breaking loose.
Blazen Js
At this point in time, your boat looks about like mine. I am in the process of having new interior built and currently have the complete old interior in my garage. I either sell it or I'm building patio furniture from it! Wife prefers I let it go. I don't know, but may be of some interest to you. I'll make a fellow board member a great deal! I listed on Caigslist. Search Inland Empire "complete Ultra boat interior".
ka0tyk
thanks but I'm going to be re-using my interior from my last 21 bahner that i used less than a handful of times.
only thing i dont have is the open bow seats. but i doubt you'd be willing to part with that, and maybe the hatch ram.
ka0tyk
just got my new transom seal in the mail so that means the drive, bellhousing and motor can go in. that'll be a *HUGE* step forward.
ka0tyk
little progress this weekend
little thing around the hole painted and screwed in
trim painted and screwed in
transom assembly installed, sealed, and motor mounts all ready to go
hmm... too tall for my little hoist.
after a lot of wiggling and some precarious hanging on 2x4's, etc to reposition the chain, its in. needs a LOT of cleaning on the valve covers, exhaust, intake manifold, etc but thats the easy part.
wsuwrhr
The Masheenest
Nice job.
You are a little ways from me, I see you got it in. I was going to offer up my forklift to set the motor for you.
Brian
ka0tyk
Nice job.
Brian
Thanks for the offer! I need to get me a forklift some day... I'm getting too old for this manual labor stuff.
wsuwrhr
The Masheenest
I hear that, high freeboard boats and engine hoists are usually a non starter.
spectra3279
Vaginamoney broke
I have an A-frame gantry. It it's still to short. I have to block it up about 3 feet.
wsuwrhr
The Masheenest
3 feet? :yikes
Anyone who wants to swing by is welcome to drop in a motor with the forklift.
spectra3279
Vaginamoney broke
3 feet? :yikes
I'm planning on welding some sliding legs that pin to the height needed later.
spectra3279
Vaginamoney broke
Yea, damn work distracting me from fun.
Yea, gonna follow the same angle as actual legs which are on wheels. Weld a tube to the gantry, then have a piece of pipe that just fits inside that can be slid out and pinned into place. Nice wide base and still moveble
ka0tyk
built new seat bases a little taller than the old ones. basically had to build new ones because the old carpet was near impossible to get off. also you can see where i was triyng to cut the speaker hole larger and the damn router caught and jumped and tore a big hole. gotta patch and paint that again. grr.
made vroom vroom noises in the boat with the kiddo
ka0tyk
old side panels for templates. the boat has a belly tank but the original side panels didnt really make use of the space in the gunnels for storage. there were cupholder pockets but no real way to access all that wasted space in there. you can store ropes, towels, flag, sandals, etc easily.
new ones
cutting storage holes
test fit
coated in a thinned coat of poly resin to make em water resistant. hope i have enough carpet left over
all glued and stapled up
back in the boat
rear storage pocket
front storage pocket
ka0tyk
made the mid cabin side panels complete with elastic pocket. just a FYI the pocket is pre-made and only costs $6. all the wood is coated with a coat of thinned poly resin to make it water-resistant. ive also used almost 2000 staples in the side panels, seat bases, and these. theres a LOT of stapling going on.
also purchased a cheapo boat cover from ebay just so i can keep the dust out of it when its in teh garage and im using a saw or sanding.
ka0tyk
dragged it out of the garage for the first time. im done with most of the messy cutting/grinding work so i took today to clean out the garage so i dont have to keep vacuuming everything.
i think it looks much better in the sun. i still need to buff/polish the original gelcoat, but the blue is like KAPOW blue!
yes i tow it around with my little ford focus. heh. its a torque'y little beast. my dad is gonna bring his 220v welder and we're gonna fix the fenders and build some step pads as well as fill some holes. i have a whole set of LED lights, marker lights, wiring, etc for it.
ka0tyk
drives on, exhaust is on and sealed. motors aligned. time to start doing some mechanical progress.
ka0tyk
motor will be painted the same colors as the outside. grey with blue. did the exhaust manifolds tonight. only blue will be the valve covers and brackets.
ka0tyk
been quiet but still workin...
painted valve covers and breathers... (paint looks runny but its actually brushed and tipped, after about a day it lays down flat)
gaskets to put things back together
making hose
the fitting pile (aka the moneypit)
fuel inlet side is done...
ka0tyk
salt is rough on parts...
disassemble for a clean dip and rebuild
ka0tyk
2 weekends ago my dad brought out his gas shielded 220v mig and basically rewelded everything i did with my 110v welder on the trailer after running a 50' line from the panel at the back of the house. built new step pads from scratch and mounted the fenders to em. also rewelded the swing tongue, etc. i just didnt feel safe with it the way it was... safety first!!! dont really have pics of that as we were busting ass all weekend to get everything cut off, cleaned up, and rewelded.
also ive been doing misc carpet tasks such as the rear seat base and back, and the insides of the cockpit area where your feet go. also ive been taking a buffer to the original white gelcoat so that it shines like the new paint i sprayed. its a lot of work...
K,
Post up some pics of the fender step pads you guys built! I'd love to see what you did. Way to keep trucking along my friend!
ka0tyk
I'll see if i can wander out to the garage and snap some. They're just basically boxes. My fenders sit pretty wide to the trailer and couldnt really find anything "manufactured" that fit dimensions wise. So a little angle grinding to cut out the shape that was templated via cardboard, cut a little "V" at the bends with the cutting wheel, and a homemade brake and bent up some step pads and welded em on.
Also I've been waxing the crap out of the boat trying to get it pretty. As it sits now...
ka0tyk
Still chugging away.
Battery cables are loosely in. Relay box is in. Harness is from the old boat. Dash wiring is started. Have power and illum. Gotta do the rest of the colors. Get a couple bus bars etc. it’s getting there. Put in the drivers side speaker and made a little plate to cover the hole from the side mount throttle as I have offshore throttles.
ka0tyk
more progress today
ski tow and fuel fill purple powdercoat stripped, primered with zinc chromate and painted white.
wires for illum, ground, and 12v made, harness had 3 more wires added to it.
started wiring the dash. at this point i have key on, starter, and lights working.
