So other than weight savings what is the advantage to running aluminum heads vs Iron? I’ve read you can run lower grade octane if your run aluminum, the only reason I can think of is they pull heat out better ?
Aluminum makes less power, if heads flow exactly the same.
I lied there is another benefit. corrosion resistance.but this is the only advantage
Negligible, since iron has its own problems in that regard.I lied there is another benefit. corrosion resistance.
Hmm, I have seen and changed a lot of aftermarket aluminum intakes out because of corrosion. never changed a cast iron one. I guess it depends where you boat, and closed cooling or not.Negligible, since iron has its own problems in that regard.
Considering FEW people have put an iron intake on most ANYTHING, especially a boat, in the last 20 years, I imagine your statement is true.Hmm, I have seen and changed a lot of aftermarket aluminum intakes out because of corrosion. never changed a cast iron one. I guess it depends where you boat, and closed cooling or not.
Goodness, has it been that long? Thanks for making me feel old. LOLConsidering FEW people have put an iron intake on most ANYTHING, especially a boat, in the last 20 years, I imagine your statement is true.
Sorry doooood. Last iron intake I saw on a boat was in '92, on the olds that came in my jetboat I have, which I took off and tossed the next day. I never had an iron intake on any car that I have ever owned, and that is several. BrianGoodness, has it been that long? Thanks for making me feel old. LOL
