Banshee guru
Discussion in 'Custom Offroad Builds' started by Gelcoater, Oct 27, 2010.
  1. Gelcoater
    Gelcoater Well-Known Member
    12,999
    9,512
    Sep 26, 2009
    Needed here!
    Here's the long story,
    So a couple 3? years ago life was great,making money,riding quads etc.
    I have a 1987 Banshee,owned since new. Around 07 ish I make a deal with a guy to redo my engine,barrels(his custom porting) new crank and seals,etc,in exchange for painting his 19 Daytona.I banged out the boat in a couple weeks,and he takes my engine and has it a long time.He's a buddy,not worried about him I know he's buisy with work and wasn't a big deal.
    While the engine's out I decide to go through the suspension.Denton Racing was down the fwy from where i worked,and already had their stuff on the wifes quad so thats where i went.
    Swapped out the front J arms and A arms with their kit in chrome with heim joints,Elka shocks,nice deal and bolted in no prob.
    Enter the rear and the real problem,picked up a rear swing arm+4 with billet carrier,and hardware kit along with a new chain slider.Had the shock re valved/sprung for the +4 and my weight.When i got everything home i figure out the bolt won't fit the hole that mounts the arm to the frame.Take it back they ream it,it fits,the deal bolts in.
    Shock linkage bolts up bitchen,brakes and provided fit great,axle fits carrier,and the axle nut tightens down to where it did before,but the sprocket doesn't line up with the front.Its out boarsd by almost a half inch.
    Of course I wont know its not lineing up though as my engine would not come back for months.
    So the big day arives I install engine and figure out the chain dont line up,Denton was out of buisness:swear, and Im stuck.Looking for the easiest fix here.Im thinking the carrier may be wrong? Or st up for some kind of aftermarket axle/sprocket star dealio? I dunno.
    The bike has other issues,needs a gas tank,cdi box and radiator.Is a back shelf prodject.
    Any body? :(
  2. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    A couple of the parts and one looking down the stock swing arm w/+2 extention.
  3. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Anyone?
    Ideas?
  4. speeddmn
    speeddmn Well-Known Member
    1,326
    4
    Apr 23, 2008
    That is not a banshee swing arm. It is for a raptor and they are different
  5. speeddmn
    1,326
    4
    Apr 23, 2008
    On a banshee swingarm where it bolts to the frame in front should be the same distance on either side
  6. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    HHHHHHMMMMMMMMM.
    This is something I have not noticed in the past?Might have to rip it apart and check.For some reason I think my stocker is longer on one side too?The chain slider side.
    When you say Raptor,any year? I have a 660,maybe I should measure some shit.
  7. scottietwohoty
    scottietwohoty Well-Known Member
    3,842
    114
    May 23, 2008
    I also believe that where the swing arm through bolts it's the same length on BOTH sides. I have the same chain slider and it wraps around the swing arm and the tab rests on top of it.
  8. rivermobster
    rivermobster Club Banned
    30,976
    7,721
    Dec 28, 2009
    is your old swing arm layin around??
  9. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Its on the quad.
  10. rivermobster
    30,976
    7,721
    Dec 28, 2009
    so your sayin nuthin lines up with the stock swing arm??
    I thought u had the +4 on there now??
    < scratching head
  11. scottietwohoty
    3,842
    114
    May 23, 2008
    I think he can't put the extended one on because nothing lines up.
    Sent from my T-Mobile G1
  12. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    :DThe stock swing arm is on now,and everything lines up,has a 2" extention. The +4 is hanging on the wall as art,every thing bolts up,but the rear sprocket is out board by 1/2".So to run the new engine I put the old(stock) parts back.
  13. rivermobster
    30,976
    7,721
    Dec 28, 2009
    so was speedmn correct? that was a pretty good call he made!! should be easy to see if you stand the quad no the grab bar.
  14. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    That will be the next step,got to finish cleaning the garage first.
    If indeed thats the deal,I have no clue how to fix it.Although it may fit,it has no buisness on my Raptor,the Banshee's the one that needs it.
    Anybody know,or know who used to make parts for Gary Denton Racing?Maybe they can make me a trade/deal on my useless to me parts for what i need?
  15. rivermobster
    30,976
    7,721
    Dec 28, 2009
    +4 for a raptor would be an Easy sell on Ebay. lemme know when you need a new one for the shee. I can prolly help you out there.
  16. cave
    cave Well-Known Member
    3,049
    20
    Dec 22, 2007
    Hey Gelcoater, from the pic you posted the bearing carrier hub is not centered, here is a Lone start Swing arm for a Banshee.
    [​IMG]
    notice that the bearing carrier hub is equal lengths on both sides
    Here is you pic
    [​IMG]
    The carrier hub is off to the right. Looks like the Swing arm is a blem. If you have any fabricator friends you could have them plasma cut it off and re tig the carrier hub back on. You may loose a 1/2" and need to re-chrome it. That is if it worth salvaging.
    Here is a raw pic of what Cascade sells, notice the how the hub is equal on the brake side and the chain side.
    [​IMG]
    Who ever fabicated the arm may have tried to compensate for the brake caliper mount. If that's a top pic.
  17. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Cave,thanks for taking time to post.
    After reading I went outside and looked,seems equal on both sides,must have been the angle I shot it from? The carrier bearing itself looks the same as yours,so something is screwy with the arm.
    Im thinking next week I may reinstall the parts and take a few more pics,and go from there.
  18. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    OK, I haven't swaped parts yet,BUT! I have confirmed it is NOT a Raptor arm.The shock linkage mount is about 1 1/8 wide on my part(and fits a Banshee linkage great when it was on the bike)the raptor linkage was 1 7/8 if I remember from last night.
    My only question is did the 660 and 700 have different linkages? I checked on a 660.
  19. rivermobster
    30,976
    7,721
    Dec 28, 2009
    pretty much everything is different on those 2 quads.
    i would guess the linkages would not interchange
  20. proshop
    proshop Member
    15
    May 6, 2010
    that swimgarm is made by firebell racing (559)324-9533. they make great stuff give them a call
  21. RiverDave
    RiverDave Banned
    82,557
    35,771
    Sep 13, 2007
    Welcome to the board Proshop!
  22. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    7 year bump.:oops:
    I took the wall art swing arm and carrier to Inland ATV in Loma Linda on Redlands blvd.
    Stood the arm up to a known Banshee swing arm. Exact in every way.
    The carrier, exact in every way.
    So, the banshee comes it of the shed next week to try and mount this again.
    The guys at Inland ATV were very helpful, and patient. :cool:
    They invited me to mount it and bring it in to help figure it out.
    I rode it almost a year ago in March. Broke the bolt on swing arm extension thingy on the stock arm.
  23. n2otoofast4u
    n2otoofast4u Well-Known Member
    725
    549
    Apr 7, 2015
    Are you using a stock 35mm axle and stock sprocket hub, or aftermarket stuff?
  24. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Stock axle, stock hub, sorta..
    Is an 87
    87 came with 4 bolt sprocket hub.
    I lunched mine at some point.
    4 hub no longer available, switched to later model 6 bolt. All fit fine, worked fine. For years.
  25. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Funny side note.
    Ordering that sprocket hub.was late 2001
    Was at Malcom Smith ordering it and my wife was with me.
    young parts counter kid brings out the 6 bolt deal.
    I tell him it's wrong, mine's a 4 bolt.
    He says it's a 97 Banshee part.
    I say no, man. 1987.
    The kid starts punching keys and stops.
    Looks at me and says my computer doesn't go back that far. I need to go look at micro fish. Lol!
    The manager intervened to let me know the 87 part wasn't made any more.
    Meanwhile my wife had shit she wanted to do and is getting steamed.
    As we were leaving she was going on about how rediculous that whole deal just was and I should just buy a new quad.
    :eek::eek::eek:
    Called Alba Motorsports the next day and bought a Raptor over the phone:D
    My wife only has to tell me once to go buy a new toy. :)
  26. rivermobster
    30,976
    7,721
    Dec 28, 2009
    Holy thread revival!
    LoL
  27. thmterry
    thmterry Well-Known Member
    1,077
    507
    Jul 29, 2011
    I paid $2790 otd for my 1st banshee in 1987 for an 88 Banshee. I have had at least one Banshee in my stable ever since. Currently have 3 with one being a 100 hp dune machine :D Most fun you can have at Glamis!!!!!!!!!!!!
    wsuwrhr and Gelcoater like this.
  28. poncho
    poncho Well-Known Member
    2,696
    1,105
    Dec 20, 2007
    Used to run my CJ-5 on paddles at Sand Lakes in Oregon, chatted up a guy one day on a custom Banshee and we decided to trade rides for a few minutes as his G/F wanted them to get a Jeep.
    Holy Hell, no idea how much HP but he said he had 10g's in his motor=1995
    That thing sucked up every bump and had pull like the devil, amazing fast.
  29. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    We got these 87s at the end of 88
    Yamaha couldn't move them.
    A new Honda was $4,200
    We got the 2 Banshees for $2,400 each. For that price they came with nerf bars, paddle tires and pipes.
    Got them from the now gone Sunwest Cycle in Corona.
  30. wsuwrhr
    wsuwrhr The Masheenest
    29,946
    17,606
    Dec 20, 2007
    Inland ATV know what they are doing. Good peeps.
    Gelcoater likes this.
  31. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    Nice. Lets hear about it if you haven't before.
    I run a 535 10MM stroker with a T Rex and CPI big bores 220psi. 100 on a wheel dyno. I love that ol girl. :)
    pwerwagn and thmterry like this.
  32. thmterry
    1,077
    507
    Jul 29, 2011
    Basically mine is the same. Mine was the bike that Dan at DASA prototype the TRex stuff on .
  33. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    An old picture of mine after I built it, this is in the riverside shop before I took the graphics off and changed the seat.
  34. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Fairly sleeper.:cool:
    wsuwrhr likes this.
  35. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    Yessir. My wifes looks identical, minus the pipes. ;)
    Ill usually race my wifes bike and if I get beat, I cut out early and go back for mine before everyone else gets back to the line. ;)
    Brian
    pwerwagn and poncho like this.
  36. pwerwagn
    pwerwagn Inmate #4800
    1,167
    885
    Aug 28, 2010
    Mmmmm. I can smell the two stroke thru my phone! Makes me happy.
    wsuwrhr likes this.
  37. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    What pipes are those?
    wsuwrhr likes this.
  38. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    CPI big bore.
  39. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    What would you suggest for something about 400cc?
    I been looking for a clean set of T3s but have t found any.
    I like how your pipes tuck, like the T3 and the Klemms I have.
    The Klemm pipe is fine on a stockish unit but gives up top end vs the T3
    wsuwrhr likes this.
  40. Waffles
    Waffles Well-Known Member
    2,224
    1,795
    Jul 12, 2012
    I'd put my money on a set of shearer or sniper pipes
    Sent from my FRD-L14 using Tapatalk
  41. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    Shearer pipes are good too for smaller bores.
  42. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
  43. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    I almost want to say the CPI big bores would work on a 400cc.
  44. n2otoofast4u
    725
    549
    Apr 7, 2015
    GC what is the bike intended for? Just dunning, little drag, overall just a play bike?
    On a 400 (I'm assuming a 392cc stock stroke cub?) you will want to run a small bore pipe. As suggested earlier, the Shearer or Sniper would probably be a good fit on a bike setup like described above. Typically those are a bit more expensive, and a bit harder to find on the used market. I would personally probably run CPI on that, but lots of guys are having great results from the SLP pipes also. I'd stay away from any of the Toomey stuff unless you are looking for more of a trail type pipe. They don't create much more down low, and sign off really early. Be warned, the Shearer chrome SUCKS! Most of all DO NOT buy anything from Motor City! Guy is a crook!
    If you're into fast bangshee shit, some of the fastest bikes in the country will be racing in Bakersfield February 1-4. Lots of 50k bikes at that race.
  45. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Ported Yamaha cylinders, 66mm bore, +4mm crank.
    Mostly a dune quad, with a flick up the hill or the flat drags on occasion.
    Made some room in the garage today and dragged the thing out of the tool shed.
  46. n2otoofast4u
    725
    549
    Apr 7, 2015
    Easy on those cylds at 66. I'm assuming you have some sort variant on a cool head with domes to keep that bore in check, or at least a well worked stock head. If that's my setup, I run CPI small bore.
  47. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Thanks for the input!
    No, no cool head. The stock head was massaged quite a bit to work with the stroke;)
    So, CPI small bores...
    I'm really glad I haven't saved receipts over the years on how much has been put into this thing.:confused:
    Pretty sure I coulda had a corvette:mad:
    :D
    wsuwrhr likes this.
  48. wsuwrhr
    29,946
    17,606
    Dec 20, 2007
    Good luck airing out the corvette. ;)
  49. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    Gimme da keys!
    wsuwrhr likes this.
  50. Gelcoater
    12,999
    9,512
    Sep 26, 2009
    I have another question for you guys. A couple actually.
    First.
    The engine has a Ricky Stator deal on it with adjustable timing plate.
    Right now zero is in line with the part line between the upper and lower engine case.
    Where should it be for optimal power/reliability?
    Second. Gearing. Last time out I ran a 14/44
    I run an 8 paddle Dico turf tamer straight paddle, 20x11-9
    It felt too low. Just spinning tire.
    I didn't play with launching it as I knew that other rear end was on borrowed time.
    I'm thinking 14/41 or 14/42 this time?
Share This Page
