bowtiejunkie
- Nov 17, 2016
- 1,701
- 2,364
I'm not versed on jets, so excuse any wrong terminology. A cousin of mine just bought mid-1980's jet boat, with a Berkeley Jet pump (looks closest model 12JG from looking at Berkeley's website). He didn't do a water test before buying. We took it out Sunday and had basically immediate failure (cracks 3-4 inches long) of Suction Piece at 10 o'clock a 2 o'clock position in area where it bolts to bowl. Looks like a disc or similar pierced through. Metal shavings were everywhere along with a ton of water pushing in. It first broke through on Starboard side of Suction Piece. We noticed it, but tried to make it back to ramp, when boat engine overheated. That's when we noticed a ton of water in boat, and the port side of suction piece cracked. Had to get towed back to launch ramp. Did the wear ring, impeller, or pump shaft left go?
I also noticed a good leak at what I believe is the Suction Piece seal.
I'm curious what went wrong. Any idea on costs to fix this?
We had engine cooling problems too (which I'm not sure if this is related to Suction Piece developing cracks). 454 BBC. Engine would run hot (240+) idling in no-wake zone, then start cruising and it would cool to below 200* (could feel outlet hose was cool), but the engine temp would jump past 250* within a few minutes. We had valve on exit hose open all the way. Any ideas?
Thank you.
Thank you.
