ChiliPepperGarage
Well Known RDP Cart Returner
- Mar 8, 2008
- 4,264
- 9,232
Our air compressor at one of our fire stations crapped out so we got a new one and I'm trying to wire it up. There is an upper box and a lower box. The upper box is just an on - off box. The lower box has what appears to be a breaker of some sort (smart breaker?)
The old compressor had separate wires for the motor and regulator. The new compressor has only wires to the regulator. The motor is wired to the regulator.
I disconnected the old compressor and wired the new one from the regulator to the same terminals as the old compressor motor connections. When I turned on the power nothing happens.
I'm thinking I have to wire it differently but not sure how at this point and trying to avoid the cost of hiring an electrician (we are a volunteer department).
I thought about wiring it it to L1 & L2 but then thought I wouldn't have a breaker. Maybe I should connect the white and black to where the old compressor regulator wires were? One went to L1 and the other to the slide connector (see photos)?
Maybe I need to just get a new breaker and replace this one?
Thanks.
Thanks.
