Andy B.
- Jul 19, 2011
- 5,379
- 7,321
View attachment 600454 View attachment 600455 View attachment 600456 Changing out the Wheels tires and Fenders.
Cool dog oh and the boat is pretty awesome too!
Boat & trailer look great! What's the story on your engine build? How does it handle now with the new tabs & steering? Need more pics.
The tabs and steering made the boat alot more responsive and stable, small tab movements make a big difference and the steering is very solid/tight at speed. Could not be happier with the engine upgrade the power curve will put a grin on any ones face. Still sorting out the setup and searching for the right prop and drive height combo. Out of the box using the same 23 Mirage and lower unit as the old engine I have seen 16+mph gain and significant increase in acceleration, engine just continues to pull through the whole RPM range does not start to go flat or get lazy at the top like a lot of marine engines.
Ya, I was kind a bummed, I would have loved to run it but I had just discovered that the drive fluid was leaking pretty good after snagging some fishing line. Next timeBoat looked great out on the water last week.....was hoping to get a run in with you leaving the no wake buoys on friday but you seemed to be breaking her in and taking it easy.
Bummer hopefully it’s no biggie.
Ran into a buzzer when starting on Thursday...turned out the little drive fill resi was low.
Leaving foxes Thursday the boat wouldn’t start until we pulled the air cleaner... boat just doesn’t like the cold water starts with the 1050 carb.
Boat shit[emoji12][emoji41]
what kind of speed have you gotten out of her so far?
seems like you should be pulling a 26 or labbed 28
Tried a 26 Bravo 1 but chine walk was a bit much. Only other prop I have tried so far is my old 23 & I am right around 80 on the rev limiter with the 23. We will see were it ends up, have one prop being tweaked right now and another on order. I'm still running the standard length Bravo and will be going to -2 at some point.
Are you running a 3 or 4 blade? Any chine walk?
Motor must be pulling a high rpm with the 23?
Boat is solid with the tabs set at 3 on the gauge but still moves around a hair. Anything less than 3 on the gauge and things could get dicey pretty fast and i would never rik it without a lifeline and zero family in the boat.It might have a little more top in in her running ragged loose but the boat is very solid loaded and still runs 80+ in the summer.
I run a labbed bravo 28 and have seen a little over 87 gps (light load and gas)
My boat won't pull the 28 like I would like and I only see like 5200 rpms (pretty sure its over cammed) but it actually runs a better # at a lower rpm compared to a 26. The boat would blow out a 26 at will and I didn't like how it turned with the smaller prop.
Most of the Gel on the exterior is original to the boat I had the blue stripes redone with the silver/pearl and cleared. Orange County Boat repair did all the exterior gel work repairs, color sand and clear.Where did you get the gelcoat work done? Looking for a place in SoCal
"With in a budget" LOL, that is how I started. The original cost estimate to repair all the Gel Coat scratches, gouges and damage on the exterior and color sand and buff was around $ 2,800. The color change on the Blue stripping to silver pearl, clear coat the boat and re due the bottom (fix scratches and re gel) added another 3k. Every Boat is going to be different even if they are the same make and model. All depends on the condition and what type of damage needs to be repaired. If there is fades the cost could be more. Mine had some pretty good gouges on every corner and the bottom keel was pretty worn.If you care to share the cost of such work would be greatly appreciated, if not no big deal.
I need to have some gel work done on my 210 within a budget...LOL
Have you guys tried 5-blades. I like my cutting edge 5-blade a lot better than the bravo one I’ve tried. (Note. I have a 240)
Can you snap a photo of the front of your engine showing the pulleys and front of the motor? Putting my motor together and would like a picture to reference
What differences did you see using the 5 blade vs the Bravo 1? I have been working with Cutting edge on my 3 blades.Have you guys tried 5-blades. I like my cutting edge 5-blade a lot better than the bravo one I’ve tried. (Note. I have a 240)
I have heard the Rev 4 works well with the 210. What size are your using on your 210?I settled on a Rev 4. Your 240 is heavy. An overall lifting prop like the Rev 4 works well. A B1 is a stern lifter.
If I remember I think thrrox has more the stock power for that 5 blade.......
Thanks,23. A 23 Rev4 is like a 24 B1. Blades have more cup. They have a 25 and 27. I bet the 25 would work perfect for your power.
I have a rev 23p on my 240.....kind of want to try the rev 25p and have been looking for used but no dice.....
What power do you have in your 24?
502 415hp. I'm thinking not enough hp, but maybe doable in cool weather.
What rpm do you see with the 23 now? I run a 23 in my 210 with a 496HO. I am dead on 5100 in the summer. Remember all about propping for when you boat.
I've never ran it to the rev limiter. Always been nervous to do so, motor starts to scream around 4-4200.... I don't want to have a rebuild on my hands ha ha ha
View attachment 617782 View attachment 617784
The alternator and power steering clearance is pretty tight with the power flow manifolds I am using.
You're not going to hurt it. The Rev limiter is 5100 on the 415hp 502 Mpi. You need to stretch her legs!
Will be out first weekend in March. Might just have to do it.
You think it’s possible to spin the rev 25? 23 works well all around just looking for little more speed with less rpm. When running from the spring to pirates.
I think the 25 will be too much prop for your combo in the warm weather. Summer with people, full load of fuel and gear it will probably struggle. Try it though.
He is doing well, still abit of an asshole at times. Likes to take anything that you show any intrest in and he can grab with his mouth. He does have skin allergies so we have him on a grain free diet.View attachment 600454
How's your dog doing? Bailey is getting pretty old over here. Walks with a limp. Wonder if we brought them together if they would even know they are related......
What brand guages did you go with? I want to do mine as well and it looks so tight on space for bezels
Thanks, looking forward to trying a couple of those props.great thread buddy,... you did very well on this refresh...hope to see it on the water soon...
