New Home Const
OutCole'd
Raging Member
Great thread! Keep the updates coming. I'm especially interested in the interior.
Thanks!
28Eliminator
These are pre-fabbed masonry fireplaces. 3 different sized ones are going in this house. I'm not a big fan of these, but it's what we sell as an "Upgraded fireplace" :rolleyes:
400 amp main :thumbsup
4 of the 5 linesets for the AC Condensers. This house will have 4-5 ton condensers and 1-3 ton for the Guest house :eek:
1 1/4" water main, and 2" gas main
RUNNINHOTRACING163.1
cool progress pics :thumbsup:thumbsup
Master bedroom fireplace ?????? :champagne:
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.ebay.com/itm/190649028759
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:drnkfr
28Eliminator
28Eliminator
Thanks!
The interior is gonna be pretty nice.. We have over 7000 catalog options, and I think they picked most of them.. then added a bunch of custom options to that :thumbsup:D
fmo24
X2 on the great thread. It always amazes me how crazy engineers can get.
28Eliminator
Made a lot of progress over the last couple weeks. Here's some updated pics.
This is the reason I have a job... Hacks :grumble:
This is the other Trellis in the courtyard. It's between the main house and the Guest House
Some of the roofing material
About a million feet of Media cables in this place :eek:
Cable and phone are in the top box. Alarm system in the bottom box. This is the standard in all of the homes.
This is a shot of all the Media, Plumbing, Electrical, Security, etc going through the Portico over to the Guest House. The picture doesn't do it justice.. The orange pipe going up the wall is the Fire sprinkler for inside the portico :cool:
28Eliminator
Pool and Spa have been dug and steel'd. I had to get it done a little early because this place is landlocked, and there's no other way to get the tractor back there after I get the Block walls built.
Spa
Pool
Windows are mostly all installed
Haystack :p
Between the Bituthane, moistop, and corner flashing... I think were good on moisture infiltration around the windows :rolleyes:
28Eliminator
Well, Lath is all completed. Pool has been gunited, and most of the Butt Glass has been installed. Once the Drywall is hung, we can start scratch and brown coat.
Below; We put a protective coating on all the Butt Glass to try and keep it from getting destroyed throughout the const process.
Portico entry, Courtyard side
One side of the autocourt walls in the front of the house. Note the drains and irrigation line in the column
Trenching for pool plumbing. I have 2 separate lines run from the water meter. One for the house water (DUH :rolleyes:), the other for the Irrigation and pool auto-fill.
28Eliminator
Last week we had the "Buyer Pre-Drywall walk". The Homeowners, Designer, Electrician, Media/tech and myself all walk the house and discuss locations and design of all options, and clarify any questions they may have. And as usually happens, we end up adding and changing a bunch of shit :cool:..... Change Orders :D
I got Framing inspection (combo), or as some call FEMP (Framing, Electrical, Mechanical, Plumbing) on Tuesday.... No corrections :champagne:. Well, that isn't exactly true. Buiding inspector had no corrections, but the structural engineer (which is now required to walk and sign off on the homes) had a couple items for us.. None the less, all done now, and we started Insulating today.
Here's a pic of the Grotto Hood were putting in this house. I had to get it framed so we could figure out the actual kitchen cabinet layout. cabinets had to be ordered a week ago, in order to be here by the beginning of June.
The access hole you can see here (going through the truss blocks)was a topic of contention for the Structural engineer. It had to be there for access to the FAU units that are up on a gangway in the attic. We changed this years ago, but he forgot, and of course couldn't find any paperwork on it. So we got to hash it all out again. After a mountain of emails and sketches back and forth, the engineer said "just add another block next to it"... :grumble:
Starting insulation. Hopefully done by Tuesday.
28Eliminator
Drywall is all hung. Inspection today and metal starting
28Eliminator
Brown coat will be complete today.. Foam and precast details already going up...
28Eliminator
Here's A few more pics
At this rate, we'll have the smooth coat done by Tuesday or Wednesday...
28Eliminator
Glad you got it hung so fast, now tear all this shit out and fix it... Lol!!
ImageUploadedByTapatalk1337364466.792963.jpg ImageUploadedByTapatalk1337364511.082715.jpg
Jeff and Jen
Does your Media tech do Automation as well? If not, I would be interested in talking to you about this. We specialize in high end custom residential home automation. We are a Crestron dealer/programming. We are based in San Bernardino and have clients all over the world, so travel is not an issue.
Give me a call if you are interested.
I look forward to hearing from you.
Jeff Adams
JEA Designs
909-553-3338
28Eliminator
Update... Yeah I know, it's about time.
Drywall and texture is all complete. Texture turned ouyt to be a pain in the ass, as the designer didn't like the samples a few times :blah::blah:.. anyways we ended up with a "medium soft" hand texture... whatever :rolleyes: ceilings and garages went with standard orange peel.
Doors and casing have been installed, as well as most of the cabinets :cool:. Our cabinets come from Canada, and entail an epic amount of crossing T's and dotting I's to ensure that we receive them on time, and the order is complete. Our cabinet company as well as ourselves did our job, but the mfg screwed the order all up.. 6 more weeks to get anything from them :cool:
anyhow, were painting the interior now. That will take another week. Granite has been measured and templated and is in the works. Shower Tile is underway, but there's a lot to do.
Here's a few pics
Kitchen, just after cabinets came
Bath#3
Bath #2
260 square foot Master Closet. Wait till you see the shit going in here :party2:
28Eliminator
Exterior is painted now. Roof is almost complete :grumble:... slowest roofers in the valley :rolleyes: of course I'm not sure I blame them... roofing in 110 degree weather would not be fun. They should be complete today.
been trying to get the courtyard fireplace going, but the building dept has decided they want to make it as difficult as possible to ever build it :grumble:... 3 weeks in plan check, for a fireplace we've built over 100 times out here :headscratch:
Here's a few pics of the exterior work.
Front of GH garage side.. not a big fan of the scallops, but I just build em..
Precast window ledge. made with recycled glass ;)
My goal was to have the trellis beams match up with the bottom of this cornus mold... Got lucky :D
Trellis at the other side (kitchen). I had to use Milcore around these ends of the beams, and pocket them... caulking :D
More of the CY trellis (Guest House side) after paint
Better shot of it between the Main house and Guest House
:cool:
One day this will be a Fireplace :grumble:
28Eliminator
Update;
Most of the counter tops have been installed. Granite is standard for all of the tops in all our homes. Buyers can pick from a variety of stone tops and edges as standard, and upgrade from there. These people did some pretty nice stuff.
The rest of the Cabinet and millwork has been completed, Finish plumbing is going in, Fireplace surrounds are being finished up, and finish electrical and Media are underway.
Den built-in's
Master shower they've been working on for 5 weeks :grumble:
Master bedroom fireplace surround and Tile work
Powder room tile and granite. Cool glass vessel sink going in here :thumbsup
Trple pencil edge
Guest House Media center
Kohler bath fixtures :cool:
Master shower
Living room FP
28Eliminator
Not sure they're ever going to finish this :grumble: week #3.. and they still have a rather large courtyard and sideyard to do..
I may need to call in reinforcements :rolleyes:
NdaWind
When I win the lotto I know who to call - Stuning work
28Eliminator
I can't believe its been over 3 months since I updated this... Well here we go
A few random pics
Kitchen cabinets
Trees installed in the courtyard, looking towards the entry. Guest House on the left.
Driveway installed
BUilding the outdoor bar/BBQ
28Eliminator
A few more interior shots.. from the last couple months
Fireplace with the finished firebrick. The 2 wires are for switches to turn on their electronic igniters :rolleyes
Sideyard flatwork going down
A sample of the Faux paint for the Homeowners to approve. They kept wanting it darker until we layed out a bunch of the flooring to convince them it was going to be too dark. They finally agreed :D
Firebrick in progress. there is 3 fireplaces in the house, and 1 in the courtyard
28Eliminator
We made the completion date, actually a little sooner. Final construction complete date was 10/26. At that point our Warranty Service dept schedules the walkthroughs with the homeowners. We do whats called a "72 hour walk", which is basically the creation of the punchlist. Myself, the landscape Architect, the pool company and the Designer all walk the house with the homeowners. 3 days later (72 hours :p), and we do the "Homeowner Orientation". They are introduced to the Concierge company, Security Company, HOA, Pool company, and a couple other useless trades trying to sell their services :rolleyes.. I dont show up till after they are all done :D, we walk the house again, list any incomplete or pending items, and show them how everything operates and answer any questions they might have. Oh yeah and we give them the keys :D
Heres a few shots of the finished product
Back yard finshed with the patio furniture
Den, desk and bath door
Den bookshelves
A small cedar lined closet they wanted off the Master Bath
One side of the Master Bath. In the mirror reflection you can see the other side
Another of the same shot, but you can see one of the doors going to the Master Closet
Master Bedroom fireplace with Built-ins on both sides
A shot of the Powder Bath, and my ugly mug :D
28Eliminator
some more interior shots
Living room, looking from Family room
From Family room, looking towards living rm and Master entry and hall
Looking at Entry from Living room
Wet Bar, ooking out towards pool
One side of the Kitchen. To the right, through the doors is the courtyard trellis and entrance to the Guest house
Other side of the Master Bath
One side of the Master Closet
28Eliminator
A couple more shots
Sent from my iPhone using Tittytalk
Here's a few pics
Bath#3
Bath #2
Cabinets & Tile are looking :thumbsup:thumbsup
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :thumbsup:thumbsup
http://www.ebay.com/itm/JETSKI-STOR..._Watercraft_Parts&hash=item2c696f3dd8&vxp=mtr
http://www.ebay.com/itm/NEW-BOAT-TRA...089d56&vxp=mtr
http://www.ebay.com/itm/LED-TRIM-TA..._Accessories_Gear&hash=item2c6501c609&vxp=mtr
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!! :champagne::champagne:
28Eliminator
Thanks, were non union :D
28Eliminator
i can't tell what did they do wrong? can't read the chicken scratch.
this house came out Beautiful!!!!
Lol.. It's hard to see in the pictures, but metal is not straight, and the arch spring points aren't even. Drywall metal guy didn't have his heart in it :D
Thanks for the nice comment!
cola
And they will spend maybe 2 months a year in it,
