OCMerrill
All in...
- Sep 24, 2007
- 26,758
- 9,957
1996 Grand Cherokee Laredo -
5.5" Pro Comp short arm lift
Some heim joint heavy duty steering
Front cross bracing for the steering box
Fox 2.0's
Some real noisy mud bog tires (who buys that shit?)
Gas tank skid
And that's it.
Now WTF was I thinking? Truth is I have always wanted to build one of these. Problem is I don't want to have $30k wrapped up into something that might be worth $7500 to the right victim and if this one is sold to make payroll like my LJ was I just don't want the $20k given away. I paid $3.7k for this as it sits.
The Good:
1. its a 1996 - This is the 1st of three years 96, 97, and 98 where all the V8 and I6 Drive train is interchangeable (minus the bell housing). Meaning Axles, transfer cases, shafts can move between vehicles. Why is that important...I will spell that out in the cons.
2. Has an I6 and not a magnum V8. V8 known fact they dont make that much power and dont live long. A well serviced I6 you cant kill.
3. The small I6 Auto is actually a better trans overall for longevity. 42RE vrs a 45RFE for the V8.
4. Roomy but not big. Trail size.
5. In this one everything works in spite of the 186k miles on it. Everything from the auto headlights to the AC to the lift gate wiper washer. Its loaded. More options than my dodge truck.
6. Its white with Grey interior and not Ruby Red or Green like 80% of these stupid things.
7. Car fax was super clean, bought new in Torrance and I am owner 6 but really owner 3 as the guy I bought it from passed the title through his kids.
8. Never an accident and service records 2" thick.
The Bad:
There is a list of things that have to be changed before I run out in the desert or mountains.
1. NP 247 Full Time transfer case - Full time high or 4 low and the 4 low is not true locked 4 low. The suckers transfer case is Vicious Coupled. Connected by clutches and fluid. No thanks.
2. Dana 35 Rear axle - LMFAO. I am not wasting a nickle on that POS.
3. Needs Recovery and because its a uni-body real bumpers need to be put on. Everything for this deal is order and wait. That part is a CON.
4. The 15 x 8 steelies and 33's are going in favor of 16" with 315-70's so I will have big 34's. 35's require a hatchet and a chainsaw but that's not exactly out of the question.
5. No Lockers - Limited slip in the front and rear. The computer applies the breaks when a wheel slips, transferring the TQ to the other wheel. Thats the Quadra Drive claim to fame. Pass.
I will add more as I go here. Pics of what it is and as I modify it. My goal is to shoot for a max of $6k in parts. Total under 10k.
So 1st mods are:
NP247 Goes and a NP 242 goes in. Cheap, easy swap, plug and play. Still gives 4 time 4wd if you select it but it has a dif inside and no Viscous unit and a locked 4 hi and low. $450
Dana 35 goes and a swapped Dana 44 goes in - $450
Then lockers? Hmmm....?
Hansen Front Bumper
Used winch somewhere
Rock hard rear bumper and tire carrier
Rock Hard Cage - A Must. Those of us that have flopped know why
CB
HAM - Thanks River now maybe I can get this going
Some LED lighting
I may long arm it. If I do then the budget grows about $2k but I can stiffen the Uni-Body.
So lets see what I can do with this. Thanks for reading.
