Purchase a rzr few months back .
Don’t no shit about these tires being a boat guy . Tires came with the rzr
These tires junk ? The paddle part looks good
They look like sandtires unlimited with custom comp cut. Should work great, just want to make sure your in sand and not running over bushes or rocks with tires cut so thin. Sand tires can get comp and or performance cut. Depending on how you want the car to drive and or use. Comp cut tires are trimmed down to make them as light as possible. Hope info helps
Those tires are garbage put them by the side of the road for the trash man tonight, btw whys you’re address???
No those tires are perfect for the dunes but as said before sand only no dirt they will get torn up fast if not in sand. Probably about 6-9psi air pressure
