Rigging pictures
72Hondo
Post your rigging pictures.
This was all AN and hard lines for water.
SPECTRALEN
Reenforced alt. bracket, battery switch mount, carb spacer and cable hold down, led nav lights in rub rail screws, too much other stuff.
SPECTRALEN
Where did you get those lights?
Ebay. They came from China and took a little while on the shipping. I think it was a 20 piece package with a bunch of different colors and they wire straight up to 12v. Might have cost 5 or 6 bucks. The screws I used where slightly larger than the rest of the rub rail ones. I just mounted the screw in my drill press vise, used a cobalt bit and kept it oiled on low speed, then siliconed it in from the back and snugged it in place. I also had to grind down the diameter of the screw head to give it a similar fit in the rub rail as the rest of the screws.
