SJP - LHC House Garage - project
SJP
WHTBRD
So I have been putting this project off for a couple years to see exactly how I liked working in the garages at my place. I have a detached RV and extended 3 Car boat deep on the house. Both garages have cutouts instead of shearing walls which make for nice workspaces. I actually work (hobby) in the garage (weld, grind, general toy maintenance) so I am really trying to couple that with making the space look nice. Finally I enjoy garage boating. :D
In the RV garage I put in a loft when we first moved in. Great move - stores the seasonal items and keeps a lot off the floor. It has a winch come along on the metal I beam. Also using the I beam saves you from poles and wasting floor space. More on that later. I will post some bett pics in this thread I just wanted to get it started.
First thing is getting house garage cleaned out and moved over to RV garage. I had no idea how much stuff was in there. Decided to do this project while my boat is @ Barrett's. Multitasking.
Clean slate. Time to layout cabinets, make some descions on floor coating, lighting, and reararange items on walls. Kind of a pita but after doing this project @ my place in HB it is easier to do this all at once.
TrojanDan
Is Joker epoxying your Havasu garage floors? I remember pm-ing him back in Nov and he mentioned he was possibly doing your floors this January. I am game for epoxy floors here in Havasu if he ventures into it. :cool He wasn't quite sure how long the bead blasting would take here in Havasu.
SJP
WHTBRD
We are working out options right now. Regardless floors are getting done.
*** Below is a rough Version 1 mock up of the cabinenents and benches going in. I will keep updating as I rev the design. It will then go to www.baldheadcabinets.com for a CAD drawing.
TrojanDan
Looks nice. I'd throw in a utility sink next to the water softener if you don't already have one in the garage. :cool
SJP
WHTBRD
Good idea. The problem with all of this is space is such a premium. I do not want to box myself in but I know what organized chaos looks like as well so anyway. My laundry room right inside has a sink but one in the garage... I have always thought of putting a head in the RV garage. IDK working on getting Joker to do the floors.
SJP
WHTBRD
Rev 1 mockups came back from Peter @ Baldhead
El Guapo
HAVING FUN
Gonna be Bad Azz... love the work bench area....
SJP
WHTBRD
Electrical work in progress.
* Accent 4 inch cans for the cabinets
* a bunch of 6 inch cans to light up the garage
* reconfigure outlets around bench
* build enclosure around water heater and HVAC
SJP
WHTBRD
It was a pita working around sprinklers and what not but they got it done. Patch and paint next in preparation for Joker and I to do the floors. Lava flow
Sandlord
Do you think the light form the cans is going to be enough?
I'm trying to decide between cans and fluorescent lighting now. which is better?
SJP
WHTBRD
I did this project in my HB garage and the cans are awesome. Best part is they are dim-able and I put even more density in the one in this thread. There is going to be a ton of light in garage.
Boat211
Looks bitchin. I really enjoy seeing everyone's bad ass garages.
Reactions: SJP
SJP
WHTBRD
Paint was completed and rough wall for HVAC in place. Time for floor prep with Joker.
Filled in the joints and started to acid wash floor.
Ready for primer and epoxy tomorrow.
CoronaChris
looks great....I would love to do my garage floor but I think I would ruin it.
I can do your floor for you. $3.50 sq ft fully flaked polyaspartic clear coat out of corona also. How come you didn't fully flake this floor? looks like you just used epoxy base, hate to break it to you but that floor is going to fade, epoxies are not uv stable. also would have left the expansion joints they are there for a reason. I starting to sound like a player hater but just wonder why? pricing?
djunkie
Broke mo fo
I was kinda wondering about the expansion joints too.
Joker
FYI, all you are seeing is a primer. We are doing a lava flow floor. I understand if left alone it will fade. This is what I do.
With regards to the joints, I fill every joint on every floor and they don't transfer. I'm not about to squeegee out a polyaspartic and have it 1" thick in the joints.
This floor won't even touch $3.50.[emoji115]
CoronaChris
versatile lava floor and 4195 whisper grey epoxy. just never understood the joint fill, I like the fact that if the product got damaged or the concrete cracked and took the coating you can fix a section within the joints. this is what i do to and you should look into a dust vac instead of hosing the place out, epoxy and water dont mix.. just saying
Joker
Thanks, I have that as well.[emoji106]
I'm not going to argue about how to's. Everybody has their method and I understand what an expansion joint is for as does the owner. There's a possibility it will crack.
Btw, I hate doing floors and am thankful I don't make a living doing them.[emoji106]
$3.50 is better than the lowball numbers I've seen out there for chips.
CoronaChris
no argument at all just doing my part to make sure the coating industry doesnt get a black eye, lots of failures out there due to improper prep, it's an easy fix. best of luck to you within the industry cant wait to see the finished lava flow floor.
JBS
John send me a price on my garage. 30'X38' I will help. Have all the floor equipment manual and walk behind scrubber.
Bring the wife and we can hit Steak 44 after
Joker
Jeff,
I told Sam this is the last floor I'm doing. I'd rather collect aluminum.[emoji1]
TCHB
I did my floors by myself which is nothing like this job. Much more work in this project. I am sure it will look great and hold up.
I learned a lot today about the products and the install.
Joker
Thanks for your help Tony. See you tomorrow
SJP
WHTBRD
Cool day - tomorrow putting down the clear and the color is going to be awesome. :thumbsup
Joker - Good times. :thumbsup -- Appreciate you coming out to crank this out. RV garage is next. :D
Looking forward to seeing the garage completed (paint, floors, cabinents, and finishing). Joker did my garage in HB and the joints have held up awesome. It is a super trick / clean look and functional -- cleaning between joints is no fun if you actually use your garage. In HB I park cars, weld and do a bunch of work on the floors and it has held up perfect. :thumbsup This is why I talked him into coming out to Havasu. :D
TCHB thank you for helping us as well. Having the man power there makes things run smoother. :thumbsup
BHC Vic
cobra performance boats
Jeff,
Either you or my neighbor is going to have to help me fix mine [emoji12]
Caydens Cat
all I got was a t-shirt
Looks really cool! Nice touch with filling the seems, never thought of that.
Reactions: SJP
OCMerrill
All in...
This is by far the coolest garage floor I have seen. :thumbup::thumbup:
I used to offer garage coating and surfacing. I just could never make any money at it and you have to go back 3 or 4 times. I get where Joker is coming from except I already took all the aluminum. :D
SJP
WHTBRD
Appreciate all of the positive feedback. It went on quick this morning and the weather cooperated - nice cool day in Havasu with no wind. Floor has been curing all day and has hardened. When the light hits the floor pretty cool stuff. Looking forward to checking out tomorrow when I walk it. Definetly not for everybody but I really like it and came out like I thought it would. Looking forward to next phase of project - finishing the lighting / electrical and waiting on cabinents to ship from Oregon. :thumbup:
Joker awesome job on this floor - It is killer!! :thumbsup Thank you.
SJP
Joker
SJP
As I read you say "the next phase" I about fell to the floor. The last floor I will do in 2016 looks great. :)
Yourself, your Pops and Tony all helped make this happen.:thumbup:
JBS
So you're saying there is a chance :D
Joker
Very slight, we have a better chance of going to Steak44 with you guys once football season starts back up though. :)
JBS
Sounds like a great plan :thumbup:
Singleton
What, not going to do SJP's RV garage.
Outdrive1
John I'll have the garage cleaned out for you next weekend.
GET SOME
Looks great.. Saw your morning commute this morning. Adams to harbor jeeps looked great
Reactions: SJP
SJP
WHTBRD
Thank you - hard to fly under the radar and hide in that thing :D - I had my dad fixing a few things on my daily driver so I was driving around town.
SJP
WHTBRD
Small projects - hitting the wall... Waiting on the right door to come in to cover the HVAC and water heater. Sent the painters back in to re texture so it blends better.... Once that is completed the electrical can get finished off. All the while the subs are running around town on real projects so this is getting no attention. :D The cabinets are shipping today -- hopefully in garage will be ready for them. :thumbsup
Gelcoater
That floor looks awesome!:thumbup:
And damn Joker,you're like an artist &shit.
A shame that's your last floor.
Gelcoater
Hey!
You guys suck me into following this cool ass garage rebuild and now no new pics?
SJP
WHTBRD
Hey!
Patience :D - believe me this has moved much slower than I imagined. I had this in my head take place over three weeks including emptying it. I have been watching too many home shows on tv. This is also why guys wait till end of projects to start threads I guess. :D Anyway this little project has bridged the whole winter and into Spring.
Update - the cabinents will deliver on Thursday and I have confirmation from contractor they have finished off some of the trim pieces and elictrical (he always forgets to send me pics). This is the hardest part of not being full time Havasu is trying to manage venders there. Friday we should see cabinents and benches going in. I will be posting updated pics of room.
SJP
WHTBRD
And we're off! Bench and cabinents install underway.
Joker
Cabinets look good.[emoji106]
Reactions: SJP
