Rvrluvr
CLAMP ON RACING
- Sep 24, 2007
- 7,036
- 6,432
Soaking my bird now...View attachment 603615 Whos gonna smoke their bird tomorrow? Got Miss Piggy all cleaned up and ready to rock for tomorrow
What is your plan for your smoking your bird? Can you Share your routine, seasoning and smoke time and temps do you tent it(foil warp) etc etc... thinking about doing ours on the treager. My bro in law usually does the turkey on a Weber
To be honest. I go to the treager web site and follow their brine & smoking instructions. Comes out great .What is your plan for your smoking your bird? Can you Share your routine, seasoning and smoke time and temps do you tent it(foil warp) etc etc... thinking about doing ours on the treager. My bro in law usually does the turkey on a Weber
This is what I plan on doing on my smoker.
The bird will brine for 15 hours starting later this afternoon. Around 7am I'll take it out of the brine, rinse it and pat it dry.
Rub it with a concoction of butter, italian seasoning, and a bit of oregano ... getting some between the skin and meat. Some celery stalks, jalapeños, and orange slices will go in the cavity.
Smoke the bird with fruitwood pellets at about 285-300 degrees until the breast reads 165 degrees. Take it off and lightly text for 30 minutes.
Carve, and overeat.
Thought you did it at work?Smoking one and deep frying one ,been in brine sense last night.
You might want to reduce your temp a little bit. I never smoke mine that high. Usually around 225. They cook pretty quick.
That was for our work party .Thought you did it at work?
I always start with a hotter temp to infuse more smoke at the beginning and then tone it down. Kind of like searing the juices in.I get it. You may want to smoke low for 3 hours and then crank it for the rest of the time to around 300-325.
Powered by ForumApps
You text the bird or people coming over to eat the bird?Take it off and lightly text for 30 minutes.
Carve, and overeat.
it's the opposite with pellet grilles. To infuse smoke you have to go low and then crank the temp.I always start with a hotter temp to infuse more smoke at the beginning and then tone it down. Kind of like searing the juices in.
Mine is pellet...interesting. I've neem doing it wrong...but damn it tastes so right lol.it's the opposite with pellet grilles. To infuse smoke you have to go low and then crank the temp.
cooking on high with a pellet grille is basically like having your meat in a convection oven, there is very little smoke. Its the low and slow method that gives you the most smoke flavor. I cook most of my stuff at between 180-200.Mine is pellet...interesting.
Treagar says to go hot to fuse the bird then smoke as long as you want, then crank it up to finish it off.it's the opposite with pellet grilles. To infuse smoke you have to go low and then crank the temp.
I do mine on a WSM with apple. I don't "smoke" because I cook at 325, but there is plenty of smoke. My experience is if cooked at lower temperatures, the skin is rubbery. I usually foil the top mid-way through so it doesn't crisp too much. Never tried on a pellet grill.
I thought 200 was high lol
I definitely like to send smoke signals when I open up the door the first time for bird installation. Cloudage is good and the injuns are circling now.Treagar says to go hot to fuse the bird then smoke as long as you want, then crank it up to finish it off.
I still have a rolling paper big enough for a turkwy!Still trying to find rolling papers that big JK, going to relatives ... let them cook and clean plus we haul home leftovers
