Thoughts on the Yamaha YXZ1000R - anyone have one?
Discussion in 'Custom Offroad Builds' started by STV_Keith, Mar 25, 2016.
  1. STV_Keith
    STV_Keith Well-Known Member
    2,066
    538
    Mar 25, 2009
    How do you like it? Quality? What's broke? What sucks? What's cool? What upgrades have you done? How it is compared to a RZR?
    wsuwrhr likes this.
  2. Hammer
    Hammer Well-Known Member
    18,976
    5,653
    Apr 17, 2010
    I was told the gear ratio in the trans needs to be reworked you can't stop or crawl up a hill. Good for wide open stuff
  3. STV_Keith
    2,066
    538
    Mar 25, 2009
    It has a clutch, so crawling involves slipping the clutch unless you get the Rekluse clutch kit that kinda acts like a centrifugal clutch below 3000rpm.
    wsuwrhr likes this.
  4. Hammer
    18,976
    5,653
    Apr 17, 2010
    I know I was told first gear was really high. Like slipping the clutch wasn't enough to get out of hole
  5. BigQ
    BigQ Well-Known Member
    1,234
    117
    Jan 30, 2008
    Have had one about a month and took it out for the first time to Glamis over easter. All my friends have the Polaris XP so i am a bit of a novelty:cool The car is a blast to drive in the dunes. The brakes are HUGE, the trans can be shifted with no clutch at speed, the suspension has 3 ways to adjust with compression, rebound, and spring. The one thing i need to get use to is the RPM range. You think the car is screaming and then you look at the tach and realize you are only halfway through the 10.5k range! The car itself just looks simpler to work on, lighter and nimble. I think this may be due to no belt and cooling ducting. the gauge cluster is really an information center that can be set with different options along with the shift light:thumbup:. i sat in the Polaris, Can-am and the Yamaha and really likes the feel of the car while planted in the seat, lays back a little more then the others so it has a little more "sporty" feel.
    I know that turbo systems are already out for all the way up to over 300HP (with internal mods) and that has to do with the fact the motor is very close if not identical in a lot ways the one used in the snowmobile, it's a proven power plant in various forms.
    Anyway, not much info for one time out, but it is a blast to drive. I also can't really compare since this is my first SXS and i have not been offroad since my Honda 250R 26 years ago.:D
    SJP, Beerme, Gelcoater and 5 others like this.
  6. TPC
    TPC Wrenching Dad
    21,788
    6,908
    Sep 20, 2007
    Simi Yamaha:
    [​IMG]
  7. TPC
    TPC Wrenching Dad
    21,788
    6,908
    Sep 20, 2007
    Nice, I'd like to have one.
    Guys I know with them complain of the harsh ride, and they eventually wish it was an auto trans.
    The two turbo guys are still perfecting it, some teething pains they are still working out.
    One turbo engine grenade'd already.
    I prefer a factory turbo or dealer installed.
    I'd get the recluse clutch.
    $3400 off is a great deal now.
    I've ran against them (stock) up Dumonts Comp hill with our Rzr turbo and the Yami seems to flatten out about half way up and I beat them by a few lengths.
    They sure look and sound furious.
    I wouldn't make my selection based on a car length or two in a race.
    The Yami driver position and build quality are streets ahead of Polaris.
    We love our Rzr turbo, have 100's of trouble free hours and still on the stock belt.
    TBulger likes this.
  8. Patyacht
    Patyacht Well-Known Member
    1,566
    419
    Dec 23, 2007
    There is a reason they just reduced the MSRP. The ones we have riding with us around Havasu can't go in some places like rock crawling like the RZR'S and Can-Am's do. I hear they are OK in Glamis but that's about it. Get the better clutch also.
    TPC and TBulger like this.
  9. JRS1939
    JRS1939 Well-Known Member
    3,038
    1,465
    Sep 29, 2013
    Hellllllllooooo stock shock tower! !!
    TPC likes this.
  10. STV_Keith
    2,066
    538
    Mar 25, 2009
    What happened to that one?
  11. Flying_Lavey
    Flying_Lavey Dreaming of the lake
    10,982
    4,576
    Feb 13, 2008
    Ya, what happened? And why are shocks spun 180 degrees or switched sides (can't really tell which from the pics)?
  12. BigQ
    1,234
    117
    Jan 30, 2008
    Seen this and the car that broke is not even close to stock and it has been reworked from a crash; long travel desert race YXZ with huge tires, just a bit outside of design specs if I had to guess. :D
  13. BigQ
    1,234
    117
    Jan 30, 2008
    I heard the same thing and the clutch going south. I have also seen pics of these things crawling pretty well even without the Rekluse. Some cars are being heavily modified also with clutches and gear reducers.
  14. BigQ
    1,234
    117
    Jan 30, 2008
    Dylan likes this.
  15. Uncle Dave
    Uncle Dave Well-Known Member
    3,969
    2,820
    Sep 7, 2008
    Don't have one, but driven them a couple of times .
    Great car on hardpack dirt!
    In the dunes you have to keep it boiling like a 2 stroke dirt bike.
    Its "tippy"
    UD
  16. yz450mm
    yz450mm Well-Known Member
    1,155
    980
    Jun 10, 2013
    The driver wrote that they "hit something really hard" , and apparently it was hard enough to knock the radio harness plug out of its socket. I would bet they stuffed the front end into a big whoop, and bottomed both shocks simultaneously. Doesn't look like they are running bump stops, so the full force of the bottoming out was transferred to the shock mount welds.
  17. Fabhouse
    Fabhouse Well-Known Member
    91
    83
    Jun 8, 2015
    Tubeworks makes the 70% lower first gear and (i think) 30% lower over stock 2-5 range gear set. Included in the upgrade is the increased clutch oiling system that prevents clutch failure. Look up Tubeworks.com for info.
    ***also visit Wellerracing.com, they are a dealer, and ran that set up at this years King of the Hammers. YXZ crawling with no clutch issues. ***
  18. BigQ
    1,234
    117
    Jan 30, 2008
    The serious crawlers are running TubeWorks and the Rekluse is the way to go from what i hear.
    SJP likes this.
  19. AZRiverRunner
    AZRiverRunner Well-Known Member
    249
    216
    Nov 11, 2015
    I've had one for several months, put about 500 miles on it and love it. Great for hauling ass in the desert, up steep desert terrain, and dunes. As others have said here, the gearing is tall, but if you want to crawl, Tubeworks has a 70% 1sst and 30% 2nd-5th gear reduction, that comes with improved clutch lubrication and a tap for an external Trans cooler. Yxztalk is the most complete forum if you are interested.
    Upgrades I've done...
    1. Street legal kit for AZ.
    2. 14x8 Method Racing Beadlock wheels and 28" x 10.5 Tensor Regulator tires.
    3. PRP 5.3 harnesses.
    4. Safety Cage upgrades
    5. 2" wheel spacers
    6. LED light bar
    Planned:
    Weller Racing (Desert Tuned) Suspension, complete exhaust, and ECU tune are all I plan to do.
    Croz, TPC, Bigmutha and 3 others like this.
  20. BigQ
    1,234
    117
    Jan 30, 2008
    Did you do the WR tune yet? curious what you thought.
  21. AZRiverRunner
    249
    216
    Nov 11, 2015
    No, I still haven't done that tune yet. Probably will send it in soon for the reflash and WR header and exhaust at the same time.
  22. BigQ
    1,234
    117
    Jan 30, 2008
    Well this is how the Yamaha has turned out so far..
    Cage
    PIAA Lights
    Alternator
    Graves Pipe and Bench Tuner
    My guess is will be putting in the Crower Rods, JE Pistons and ARP studs with about 12 lbs of boost.:thumbsup
    Bigmutha, AZRiverRunner and yz450mm like this.
  23. AZRiverRunner
    249
    216
    Nov 11, 2015
    Did the Weller exhaust, ECU, KOH shock revalve/spring kit, gauges, Rugged Radio and much more. Love everything I've done. Next will be tranny, need a granny gear for crawling.
  24. bead
    bead bead
    195
    11
    Jan 10, 2008
    Here is ours was some Mods, chromoly cage, reworked FOX shocks, pumper, radio, belts, mirrors, lights, 30" Mongrols/STI wheels.
  25. TPC
    TPC Wrenching Dad
    21,788
    6,908
    Sep 20, 2007
    Dealers all swearing up and down factory turbo version to appear soon.
    The Yamaha YXZ owners in our group are all dedicated Yamaha fans.
    It doesn't have to be the fastest or coolest, just above average and most of all,, a Yamaha..
Share This Page
