Using The Lifting Strakes.....
River Runnin
I need to get my boat in the air... Remove what the electrolysis has done! (Acid ain't gonna cut it!).... Sand or bead Blast, followed by wheel polishing to a mirror finish is what needs to happen! The bottom is 5086 alloy marine aluminum and .250 thick. (Sides are (.160 thick))...and about 3600#'s dry! :) ... Then a SharkHide treatment to finish it up! :)
There's just gotta be a better way than 4 cherry pickers for a couple days! :hmm
In Havasu! :)
Why not use a set of transom tie downs and the bow eye to hoist it up into the air? (If you have transom tie downs)
Adrenaline Trailers has two A Frames and can lift it for you. I think they charge 100 bucks?
