Volvo IAC
JLEE
Trying to find a IAC around here for a Volvo 8.1 gxi.
Heylam
Doesn't happen to be the same IAC used on a Mercury 496HO is it (doubtful, but never know)?
JLEE
jimmyb
On my Volvo DPX600, the gm pn is 17113099. Hope this helps
JLEE
We've tried cleaning the IAC but still have a high idle. If you see a chaparral not quite wakeless through the channel that's us. It idles uncontrollably from 1000-1400
AzGeo
Remove and clean the flame arrester . Then look inside the throttle body at '12 o'clock', for a small FOAM filter piece .
Remove it with needle nosed pliers, clean with 'carb cleaner spray' . Stuff back into the square hole when clean .
Place boat in water, or hook up a water line to the drive .
Start, and allow the motor to IDLE for 15 minutes, placing shift into gear, both forward and reverse multiple times in that 15 minutes . (650 in and out of gear)
If the IAC is good, the motor will idle correctly after the 15 minutes, if not, it's a GM part .
Does the motor run correctly above idle speeds ? This may be a fuel pump problem and not an IAC problem .
Not looking for trouble, just asking ..........
Is that photo, before or after cleaning the IAC ? Because the screws still have not been 'paint chipped' in that pic .
AzGeo
That Mercruiser IAC is actually a Ford part .......... (square with base plate and remote with hoses)
Just clean it, and then BANG IT ON THE WORKBENCH really hard, per Bruce King .
Trash
Check for a simple vacuum leak. Could be a simple line disconnect or cracked hose etc. That will cause your symptoms as well.
Outdrive1
Those fuel pumps are known to fail on those motors.
