Did you post that from photos and videos on your phone?How do I properly post a video. Posting from my iPhone isn’t working
Yes I did. And I can see your video just fine. How did you do it?Did you post that from photos and videos on your phone?
I hit attach file, then choose a video from my video files, waited for it to load. After it loads there will be a little box that says video, and I hit that and it attached the file. Then post. At least that’s how I think I did it.Yes I did. And I can see your video just fine. How did you do it?
You're the man! Just edited and attached my little video of the engine running. Thanks!I hit attach file, then choose a video from my video files, waited for it to load. After it loads there will be a little box that says video, and I hit that and it attached the file. Then post. At least that’s how I think I did it.![]()
Slowly but surely...I pulled the radiator hoses and they were full of crap. Now I want to yank the water pump and flush the block and radiator. But I’m getting tired of climbing up and down off the flatbed trailer. Now I know it runs I want to get tires on it and roll it off the trailer so I can work on itCool to see progress!
And a leaf blowerNothing like pressure washing the INSIDE of a vehicle. LOL
Do it!And a leaf blowerI found a 51? 1 ton Chevy/ GMC I think ? Is out behind a barn that that we go by next time home I’m going to see if it’s for sale , like I need another project
Coming from you that's much appreciated bud! I'm not much of a Ford guy either but I love tinkering with old stuff and bringing it back to lifeEven though I’m not a Ford guy this thing is übercool. I like what you’re doing with it and how you’re going about it.
My Gramps had a 59 Ford tilt cab flatbed with a 292 that we hauled a LOT of farm equipment home from auctions with. First truck I figured out how a 2-speed rear worked. I can still hear that thing screaming today...
Subscribed
That thing is solid enough it deserves what attention you’re giving it. I feel the common sense approach is the best for projects like these. Too many times there’s dreams of grandeur and the true meaning of the project gets obscured.Coming from you that's much appreciated bud! I'm not much of a Ford guy either but I love tinkering with old stuff and bringing it back to life
Exactly. I rebuilt the carb and installed a new fuel pump. Cleaned out fuel lines and now it pulls fuel from a plastic tank. I'm currently in the process of cleaning out the original fuel tank. The radiator hoses were trash and when I went to replace them there was a lot of debris at the thermostat housing and lower radiator hose. So next step is removing the water pump and flushing out the block. But I want to get it off the trailer cause I'm tired of climbing up and down the damn thing! Should be easy to register as it was my buddy's grandpas ranch truck and he'll sign any paperwork I may need "pink slip has been lost for years". Just gotta wait for the DMV to open up for appointments here in California so I can start the process of getting the VIN verified and a replacement title. I still have the corvair buggy! Sitting in my garage waiting for the weather to cool off then were hitting the desert! I've gotten a lot of parts from Clarks or California Corvair. Both reputable shops. I actually designed and sell Clarks an oil pan reinforcement rail/girdle for the stock corvair oil panThat thing is solid enough it deserves what attention you’re giving it. I feel the common sense approach is the best for projects like these. Too many times there’s dreams of grandeur and the true meaning of the project gets obscured.
Getting a functional cooling system and reliable fuel delivery (from tank to cylinders 1-8) are top priorities I’m guessing.
Do you still have your Corvair powered buggy in your avatar? I’m still gathering parts for my wife’s Corvair project. Another complete engine just showed up...
What does it take to get title and license for something like this truck?
Thanks I'll check them out!Nice progress. Btw. Egge automotive has tons of parts for the Y blocks if you need any. Great source.
Thank you sir! That's the thing...it's an unknown motor so my confidence isn't very high. But I've heard the one run in the truck and it has good oil pressure, no knocking or ticking. Just bad heads so far...hell maybe that's why it was parked 35 years ago?How in the world could I have missed this thread? Its awesome. Great job
@redone76 If you are confident it runs, drop it in.
Make sure the starter works on the new (used) motor, and run a compression check. Possibly a leak down test. Could possibly rig up a way to check cooling pressure if you're so inclined, lol.View attachment 947953 View attachment 947954
I hopped on craigslist and found this complete 272 engine with 4 speed trans for $250 in Riverside. Supposedly ran when the guy yanked it from a F100 a few years ago. Turns over by hand smoothly and seems to have compression. Now here's my dilemma...do I yank the heads off, have them inspected and bolt them up to my bottom end that I know is good? Or drop this whole thing in and see what happens?
Since the motor is out and easy to get to..... pull the heads. Check everything out and put on ALL new gaskets. The rope seals and gaskets they used really do degrade over time. EGGE has GOOD gasket sets. This will also allow you to inspect everything and detail the engine as well. Miles ahead in the end .View attachment 947953 View attachment 947954
I vote the "pull the heads and inspect" route. Like you said, you heard the other engine run already and know the bottom end to not be knocking as well as the cylinder bores being clean. AND its already in the truck.View attachment 947953 View attachment 947954
I've thought about doing this also. I'd have to take it off the engine stand as the starter bolts to the bellhousingMake sure the starter works on the new (used) motor, and run a compression check. Possibly a leak down test. Could possibly rig up a way to check cooling pressure if you're so inclined, lol.
Then make a decision.
Dan'l
I'm gonna do that for sure. I ordered up an engine gasket kit alreadySince the motor is out and easy to get to..... pull the heads. Check everything out and put on ALL new gaskets. The rope seals and gaskets they used really do degrade over time. EGGE has GOOD gasket sets. This will also allow you to inspect everything and detail the engine as well. Miles ahead in the end .
Totally random and totally lucky! Possibly have the trans and bellhousing sold so I'm already coming upAwesome thread! Kind of random that you were able to find a motor on the cheap that will work!
I dig threads like these during the cold months, keep up with the updates!
Exactly! Slapping on a set of heads is pretty easy on this thingI vote the "pull the heads and inspect" route. Like you said, you heard the other engine run already and know the bottom end to not be knocking as well as the cylinder bores being clean. AND its already in the truck.
I bought an old 64 f250 earlier in the year for a weekend chores vehicle and to cruise around town. It’s body is completely rusted out but interior is nice and frame and mechanical systems are solid. it has the y block with 4 speed. Motor runs great for what I’m doing, havent put a dollar into it. Gets lots of looks. View attachment 910909 View attachment 910913
Great news on the heads.View attachment 951964 View attachment 951965
Popped the heads off and right off the bat you can tell something went through the engine at one time. Only one cylinder looked like this though. I dropped the heads off at the machine shop last week for pressure check and magnaflux. They called friday afternoon and said they're good! Plan is to rebuild and reinstall as soon as possible.![]()
Right! Phew!Great news on the heads.
That is a major score in and of itself! I bought 3 sets of heads while restoring my 56.....such a PITA. You dodged a bullet for sure.View attachment 951964 View attachment 951965
Totally! I got lucky finding this engine. Crossing my fingers the heads are the problem!That is a major score in and of itself! I bought 3 sets of heads while restoring my 56.....such a PITA. You dodged a bullet for sure.
Without reading back through the thread what was the issue?Totally! I got lucky finding this engine. Crossing my fingers the heads are the problem!
Got the engine fired up and running smoothly. Popped the valve covers to adjust the valves and saw a milkshake. Pulled the heads and had them checked out. They’re junk...multiple cracks. Found a complete engine for $250. I took the heads off that engine and had them checked. All good and being rebuilt. Now you’re caught up!Without reading back through the thread what was the issue?
They're supposed to be Ford redView attachment 956133 View attachment 956134 Picked up the rebuilt heads today. Hopefully it’s drier tomorrow so I can start putting them back on
Haha! You’re funny. They’re gonna be the shiniest part of the engineThey're supposed to be Ford red
