‘57 Ford F-350
redone76
So I have an opportunity to pick up this ‘57 Ford F-350 flatbed for nothing. 272 Y-block with a 4 speed. It’s been sitting at a good friends property in the desert for quite a while and now they want it gone. Supposedly ran when parked. I’m not scared of a project and already have a few ideas going in my head. Just get it up and driving and use it for Home Depot runs? Maybe hang a Dana 60 in the front and convert it to 4X4? Cut the bed off and make it a ramp truck? Call me crazy but I like something different. You guys have any thoughts or ideas?
HotRod82
So I have an opportunity to pick up this ‘57 Ford F-350 flatbed for nothing. 292 Y-block with a 4 speed. It’s been sitting at a good friends property in the desert for quite a while and now they want it gone. Supposedly ran when parked. I’m not scared of a project and already have a few ideas going in my head. Just get it up and driving and use it for Home Depot runs? Maybe hang a Dana 60 in the front and convert it to 4X4? Cut the bed off and make it a ramp truck? Call me crazy but I like something different. You guys have any thoughts or ideas?
View attachment 910813 View attachment 910814 View attachment 910815 View attachment 910816 View attachment 910817 View attachment 910818
Awesome, I like the idea of just cleaning it up and getting it running for a home depot runner.
Seriously though, if you repower it I'll take the Y block out of it.
redone76
That's the idea I'm leaning towards for now. Going to do some research on what it'll take for a 4X4 conversion. I'll keep you posted on what I do with the engine. Let's just hope it'll run!
redone76
Drop cab on a newer chassis.
Add new flat bed sans liftgate.
Profit.
Interesting idea...maybe I'll start looking to see what I can find wrecked out there. Not sure what I'm going to do with that liftgate. It could be handy if I can get it working easily enough. Or just cut it off and scrap it
At least that way you have an easily serviceable vehicle that will ride better and you will get more use out of it.
mash on it
Beyond Hell Crew
I have a 202 transfer case. Same as a 205, but uses a driveshaft between transmission and tcase. Passenger side drop.
Dan'l
redone76
Dan'l
Cool! If that 202 will mate up to the 4 speed in the truck I may be hitting you up sir!
white tortilla
I bought an old 64 f250 earlier in the year for a weekend chores vehicle and to cruise around town. It’s body is completely rusted out but interior is nice and frame and mechanical systems are solid. it has the y block with 4 speed. Motor runs great for what I’m doing, havent put a dollar into it. Gets lots of looks.
redone76
I bought an old 64 f250 earlier in the year for a weekend chores vehicle and to cruise around town. It’s body is completely rusted out but interior is nice and frame and mechanical systems are solid. it has the y block with 4 speed. Motor runs great for what I’m doing, havent put a dollar into it. Gets lots of looks. View attachment 910909 View attachment 910913
RAD!!
ford 4x429
defiantly grab that up... Buddy's 202 and newer 10.5/d60 out of 90's f350... maybe you could find one with idi or power smoke... youd have to mess with drive shafts , but nothing cool is ever easy...
JDKRXW
That's an awesome looking truck. It looks to be a little rusty.....but far from being rusted out.
Did you change the rims/tires? I thought that truck would have had split rims?
mash on it
Beyond Hell Crew
It doesn't mate up, but rather a short drive shaft (jack shaft) to the input of the transfer case. 1350 ujoints, I believe.
Automatic, manual, Ford, Chevy, Dodge, International, it doesn't matter. Out of a 1963ish International ¾ ton 345 powered truck. I got them (2) on a package deal, with a T34 5-speed overdrive manual transmission (and other parts). I know they turn/rotate by hand, otherwise unknown condition. They do have gear oil in them.
Dan'l
gottaminute?
I may have a donor truck for you. not dual rear wheels, but a service body and rack. 86 f250 4x4, carbd 460/c6 with a/c too.
redone76
Dan'l
Gotcha. So I'd have to build a crossmember to hold the transfer case and the short drive shaft. Doesn't seem to difficult
redone76
I may have a donor truck for you. not dual rear wheels, but a service body and rack. 86 f250 4x4, carbd 460/c6 with a/c too. View attachment 910953
Wow! That's awesome! What's the story on your F250? Lemme get this big bitch home and check it out. Then I can make a game plan! Thanks!
I'd swap engine/trans/axles...so at least you get some modernish brakes. A light duty flatbed with a liftgate is about the most useful truck I could imagine owning.
redone76
Definitely a great idea...especially if I have that donor truck to swap parts with
MK1MOD0
The y blocks are great motors. Plenty of parts availability, and upgrades if wanted.
If the engine turns...I'd say it's in good enough shape to serve your purposes....wouldn't take much to get it running...but to source/sleeve/rebuild the wheel cylinders and find shoes that are worth a shit would be more effort than it's worth....Get some used 1 ton axles...I'd get a 4x4 front axle even if you're not ready to do that yet....just let 'er spin and make sure there's oil in it.
HotRod82
That is a level of cool only a few of us understand......
redone76
I like the way you’re thinking bud!
MK1MOD0
So cool. Ya just don’t see that body style anymore. So much potential!!
redone76
Popped the hood and removed the air cleaner. Nice funky smell hit my nostrils. Found a freshly dead rat by the distributor and a nice crispy one under that nest on the intake. Broke out the shop vac and started cleaning out the stinky rats nest on the intake and cleaning all the debris out of the cab
MonkeyButt70
Here is my 1960 F100 292 Y-Block with T-98 Trans and Dana 24 transfer case. I love it but if I did all over again, I would find a modern chassis and running gear for a swap, finding parts for this old running gear is HELL!
SnoC653
If that is your definition of rusted out, you need to make a trip to the midwest. That is just light to mild surface rust. Rusted out you can see through. LOL
redone76
Nastiness under the drivers seat
wzuber
Brake parts for your old trucks/vehicles.......
I came across this company recently, C.H.Topping Co., in Long Beach Ca.. They specialize in brake systems, parts and conversions, for older vehicles, hotrods etc. They maybe a helpful resource for you guys, IDK. I found them while searching for the parking brake assembly for my dads motorhome utilizing the ford f53 chassis (f550). The parking brake parts and assembly for some of these older chassis's are almost obsolete.
C.H. Topping Co.
520 W. Esther St.
Long Beach, C.a. 90813-1529
562/432-0901
chtopping.com/home
redone76
Pulled the plugs this morning and squirt marvel mystery oil in the cylinders. Let it sit and then turned the engine by hand for a few revolutions. Felt nice and smooth. Hooked up a battery and cranked her over. Turned over nicely but had no spark. Took the cap off and the rotor wasn’t spinning while cranking the engine. Yanked the distributor to find the roll pin for the drive gear sheered and the distributor shaft pretty much frozen. Drive gear on the camshaft looks good. Time to order a distributor.
redone76
She’s a runner. Need to set the timing and tweak the carb. Do a valve adjustment. Need a fuel pump and some radiator hoses to keep her running for more than a minute
redone76
How do I properly post a video. Posting from my iPhone isn’t working
DRYHEAT
I’ve wondered about this myself, I think you have to have some kind of video service posting like YouTube or something but I don’t really know unfortunately I couldn’t see your video.😕
