Boat 405
- Dec 20, 2007
- 4,462
- 8,039
Originally the engine from the Boat "Head Over Heels"
All assembly and service done by Mike Miller Racing Engines
500" Reher Morrison
12 Degree Raptor Heads with 2.450 Intake Valves. Heads worked over by Joey Grose. Lightweight undercut custom valves built to run up to 9500rpm
Donovan Aluminum 9.8 Deck water block. Motor makes peak hp at 8800 rpm. Motor made 1202hp.
4.567 Bore
3.810 Stroke Winberg Billet Crankshaft
CP Custom 15.2 to 1 pistons with super lightweight ring pack
60mm camshaft by Comp Cams
Jesel .937 keyway lifters
Manton Pushrods
Jesel Belt Drive
GRP Aluminum Rods (66 runs on the rods)
HRE sheetmetal Aluminum Manifold
Brand New Holley Ultra Dominator XP 1425 cfm. 2.375 throttle bore
Williams Segmented Dry Sump Pan
Dailey 6 Stage Dry Sump pump
XRP fittings and lines for Dry Sump
Peterson 2 Gallon Drag Race Oil Tank
MSD Front Drive Distributor
Magnafuel 4 port fuel Regulator.
MSD Crank Trigger
Headers are not included
$25,000 or best offer
500" Reher Morrison
4.567 Bore
Manton Pushrods
Jesel Belt Drive
MSD Crank Trigger
