1977 Dimarco 5/8 Runner Bottom - redo
Tahoe540
My buddy picked this boat up about a year ago and it is a beautiful original boat that was well taken care of. Well like most of us he can't leave it alone. He decided to do a complete rebuild and here are some pics of the new paint job and scheme changes. We are building a new 548 BBC with a huge solid roller and dual dominators up top with a dry sump. He is also getting a new prop made for his new setup. Lots of cool parts to make for this too.
Here is the boat in the condition he bought it.
Tahoe540
Looks awesome Who painted it?
TNT Marine and Auto Painting in Reno, NV. My friend could not be happier. He is going to buff the inside and repaint the black areas. Will keep updates when the motor build starts next week and the boat goes to pin striping in 2 weeks.
wzuber
Beautiful work!
He should order a nice work cover to protect all that beautiful work from @wannabe mom. Very reasonable and well made. I'd bet they already have the patterns too. Looking forward to seeing the progress and maiden voyage vids.
Tahoe540
Short Block is going together and the clear has been applied. Moving along and should have more motor pics this weekend. We need to get the heads on so we can build a bracket for the dry sump tank.
cofooter
Paint looks great, who did you floors? They look great, too!
Tahoe540
The painter did the floors as well. He redid the black paint and shot some clear. I agree it really does look great. Looks like motor parts are coming home today so more updates coming soon.
Tahoe540
Boat is back from pinstripper and it looks great. Also moved the name to the sides and off the bow. Got the short block painted along with some other parts. Hopefully heads will be done this week so motor build and rigging can continue.
Tahoe540
Back on track, had some life get in the way. We got the motor finally put together. Here are a few specs on the motor, should be a screamer. Should be on the dyno next week.
BBC 548 cu in
Dart Block
Crower crank and rods
14:1 compression
Brodix BB2 Xtra heads port matched to intake
Old school Weiand tunnel ram with twin dominators.
Crank Trigger
Big cam over .800 lift can't find the cam card for specifics
warpt71
Lower River Lover
May I make a suggestion? The lines coming off the water pump, if you took the left and routed it to the right side of the block, same for the right side line to the left of the block, it would be a straight shot in and eliminate the 90* fitting. Also it may end up bringing those hoses in tighter, cleaner and lower.
Love me a good dragboat resto
oldschool
Looks great. Digging that ski tow!
X2. Might want to use a recoil tube on the rope when he tows someone, it will keep the rope from getting tangled up in the alternator pulley and keep the rope from scuffing that new paint. Bitchen boat.
wettrthebettr
Your project is coming along Great
I'd like to make a V-drive box Brace like yours
Could you shoot up a photo how it connected to the drive?
wettrthebettr
I do not have a Mid plate, I have a Champion ace v-drive
It is mounted with a 1 1/8 round stock to box mount and stringer mounts.
I would have to bolt to the box mount
Photos are worth a thousand words
Tahoe540
I will try and get some better pics of his setup but those struts bolt to the stringer then to the midplate.
finally got the motor in the boat so now a bit of wiring and little more plumbing and hopefully we can start it this weekend.
wzuber
that thing is sweet...pure badassery right there. With those motor specs he may find those k&n'n filters a little restrictive. I ran them on a pump gas 540 and they were at the edge efficiency then. Will you be dyno'g the motor at any time? It would be cool to have those #'s to see right where the power band is and see what max tq/hp is. I'm guessing around 950-1,000 hp. what a beautiful ride. Well done gentlemen. Pleeeeeezzee post video of fire up day and final tune if you can. My ears and spirit could sure use some popncackle. Can you tell I'm living vicariously through you?
Do you happen to have any spare new 548 pistons hangin around?
Tahoe540
I have some used 548 pump gas forged pistons. I think they are Icon?
oldschool
This is how my C500 is braced, you might be able to do something similar.
renodaytona
Bad Ass. Can't wait to see it at Lahontan. I need to get my motor going, life definitely got in the way for me to get that project going.
wzuber
interesting but a little scary at the same time. I'm not sure there's a part in an engine that gets abused more than the piston. What rod length...6.385 or 6.535? did you run any power adders with them? Have any pics? specs., part # yadda, yadda? thx
Tahoe540
Should be back on the water this weekend for another good flogging. Ended up damaging the number 3 lifter bore for some reason and causing some valve train damage. All is fixed and ready to try again.
