mandella1day
- Oct 23, 2011
- 137
- 47
Posting for a friend, I have personally skied behind this boat many times and it never disappoints.
Boat is a 1978 Howard original gel coat, he keeps it well waxed, interior is 8 years old and still in good condition, Ellis tandem axle trailer , the cav plate hardware is showing its age after all the years he takes it to Powell for a week each year, he has new cav plate hardware for the boat. The engine and lightning headers only have 6 trips on them , 2 years of install time, he has always used the boat as a ski boat. Polished split case Casale v-drive with 15 percent overdrive , ss drive shaft guard , steel 8 degree bolt on strut, 1 inch prop shaft , 11/3/8 x 16 3 blade ss menkins prop. The engine is a 493 ci 460 ford based engine, offset ground crank, bbc h-beam eagle rods, je flat top pistons, 12 to one compression with the small chamber iron 429 head , mild porting on heads , Schneider solid flat tappet cam , trick flow aluminum rockers , Dooley 10 quart pan, weiand tunnel ram , 2 650 double pump holleys , 3/4 mag water pump
If interested contact Eddie 520-400-1423
