The smog pump is still on it but the hoses are gone. The PO changed the carb to a weber so there are a few loose vac lines floating around. I personally have not done anything to this except get it started and drove it around about 3 miles to check out the 4x4.
It is not currently registered. I have a clean title to it. It passes local smog It will not pass the visual inspection with the pump disconnected. It sat in a storage lot for 2+ years so all rubber hoses probably need to be replaced.
No smog in Yuma county. Use your trailer spot as your address with your San Diego address as your mailing address. All my river toys are AZ registered...
