1986 Eliminator Liberty rebuild...
ChrisV
Time to mock up the boat for the bunks. Finally a roller.
Had my friend followed me down the street to make sure the trailer tracks straight.
Gotta get a lower drop hitch for it to be more leveled and we're golden.
Pretty damn happy.
Marios Metalworks
Looks great so far. I bet the additional tongue weight will make trailering much nicer.
ChrisV
Loaded the boat onto the trailer today.
Got some pressure treated wood. Cut some 3" x 1/4" flat bar and bent 90 for the bunks.
Kinda wish I woulda got 3/16 steel instead of 1/8. Trailer flex a good amount for my liking. Most likely will be fixed with gussets.
Will flip the axles and put them on bottom of the leaf spring. Way too slammed.
Looks cool though.
Marios Metalworks
You are not joking about being low! I bet you still have a good departure angle since your rear axle is so close.
Hope your flex fix is easy.
badgas
Wow ! 👊
Unreal what people can achive when they want to. I'm guessing you dont play much video games or binge Netflix ?
Well Done sir
ChrisV
Wow ! 👊
Well Done sir
Haha no sir. I've never own a gaming system in my life and can't sit still enough to watch tv. Just rather be doing something.
Riverryder
it has a Jack plate no? Can’t you just lift the motor more? Motor doesn’t trailer? Like I/o?
Gonna leave the trailer raw? Or going to powdercoat it?
ChrisV
Just trying to to tilt it like crazy. I'm getting a shorter mid section so it will defintiely help.
Goal is to have it finished by Thursday night so I can send it to Embee powder coat Friday morning. There's an event June 10th I'm trying to make. Hopefully everything goes well.
MARCYTECH
that trailer looks good dude! i like it low but i understand your concern.
where did you get the tongue? i want to redo mine soon
ChrisV
Thanks!
I got it from shadow trailers in cypress. Dope store.
We have a pretty steep driveway and never have had a clearance issue.
Here’s some photos you didn’t ask for lol
Floridaoutlaw
Hey Chris, I have a 15 Mid for that motor if you need one. Is that sportmaster you have set up
for 12'' mid ??
ChrisV
I just bought one last week and send my drive out couple days ago to replace the driveshaft.
for 12'' mid ??
Duramax
Lower River Run is going to be awesome this year. Cannot wait to run with you.
ChrisV
15" midsection and setback bracket finally came. Trying to get this prop out of the water more. Idiot that mounted the jackplate to the transom, mounted it too low. (Me)
I was hitting a wall at 75mph with 1500 rpm more to go. Friend said the prop is too leveled with the bottom. Hopefully this works.
Matt Mead
My transom hangs off the bunks like that and guess what, there is a crack from the weight of the outboard, transom core wood, etc all hanging off the back of the bunks, right at the place where the bunk ends. Perfect pivot point to crack it. I did some searching and sure enough it happened to other people. They recommend when building a trailer that the bunks hang out aft of the transom (longer than boat) to fully support it.
I know you just rebuilt that transom strong as hell, but it could happen in....20 years, lol.
ChrisV
That was just quickly laid on there. I moved wood up to the bracket and also moved the boat forward 4".
I honestly don't think ill have this boat for that long. haha Maybe 3-5 years.
Duramax
I was hitting a wall at 75mph with 1500 rpm more to go. Friend said the prop is too leveled with the bottom. Hopefully this works. View attachment 1110310
Bad ass brother
Matt Mead
I was expecting you to say both those things, lol! Right on
ChrisV
Mounted the bunks tonight. That definitely stiffened up the frame.
Drilled a countersunk for the carriage bolt so it doesn't mess up the hull. Gotta keep it smoothhh
Then..... got carried away with the trailer. Added some gussets and front carpet boards cause I don't know why. Looks cool and I tend to be extra.
Marios Metalworks
Looking real damn good Chris.
Hope you don’t mind me picking your brain in the future as I refresh my trailer.
ChrisV
This is my first trailer so probably the guy not to ask hahah. Felt like I did many things wrong.
Marios Metalworks
I like your style 😎
“Hey Chris we’re ready to launch whatcha doing over there?”…..“Give me a minute, almost done bolting on my lower” 😛
Riverryder
that wood in the front of the trailer has always been something i thought of doing. but you being so talented why not just weld some screen material instead or wood?
ChrisV
This was last night random idea. I had a 4x8 wood sheet laying around. Plus I like the carpet look also.
Riverryder
it looks great. was just seeing why you would go that way. late night ideas explains it!
ChrisV
Upgrading to side steer for a better peace of mind. Old set up is held by a 3/8 bolt. Sketchy to me. Rather be safe than sorry.
IMCO is a great company to work with. Great customer service.
MARCYTECH
I Like the wood filler pannels alot. would be cool to make them out of metal and box in some of the area for a storage compartment for...things and stuff.
Chris,
Who did the work on your midsection? The guy I was planning on using is all the way over in South Carolina. Is there someone here in SoCal that does this??
The trailer looks damn good too! I'm glad you left it at that height. 👍
ChrisV
Didn't want to get too complicated... haha
ChrisV
Chris,
It's brand new from mad efi. Nobody shortens the 3.0 offshore mids. Who's in South Carolina? Some popular dude right?
As for the trailer. If I would've flipped the axles, it would raise it 4". That's too high for me. Haha
ChrisV
Another day of the trailer.
I wanted quick way to remove the fenders just in case something happens. Blow out, new wheels with different offset, who knows.
So I used tube connectors and welded it to the frame. Couple Allen heads and remove the whole thing. I'll be welding the wheel side to a 1/8 thick sheet thats the same shape as the fender. Fender attaches to the sheet. Hope this makes sense.
Mounted the lights, pretty self explanatory.
Also added a gusset to the rear end.
