Fonz69
- Jan 15, 2011
- 307
- 695
This boat was built in Shawano WI out of the Eliminator Daytona molds during the ownership changeover to Obsession boat company and originally was setup for an outboard. I had a local boat builder install the taller stringers in the back so a jet drive could be installed with your choice of motor. The heavy wood transom was removed and transom refinished. A previous owner had started a jet boat project but had prepped the hull for a factory intake location and large transom ring mount. Those holes have since been returned to factory as it came out of the mold and gel coated black again so the new owner can select which jet pump and how far a pump setback they would like to do.
The hull and trailer were commissioned by a boat company called Pacesetter and they pulled it around as their show boat to have on display so this hull was finished with extra detail and it really shows in the gel work.
This hull has never been rigged, not even a hole cut in for a steering wheel. There are holes in the dash for gauges and a grab bar that were installed for display. There are twin aluminum 24 gallon fuel cells factory installed with sending units but no holes have been cut in the deck for fills yet.
The trailer is a tandem axle with brakes and is pinstriped to match the boat, all of the lights work and some are LED.
I have a clear title in my name and the boat is cleaned and ready to go.
Asking $11,500
I was going to build this boat for myself however came across another project boat so this ones needs to go to help fund the new project.
