2.5 15" Titus coned Sportmaster 1.87 RH Fat Shaft
Discussion in 'The Outboard Church' started by Ragged Edge, Nov 4, 2019.
  1. Ragged Edge
    Ragged Edge Well-Known Member
    1,068
    779
    May 4, 2011
    Traded the Titus modified case to Stoker2001 for his stock Sportmaster. Happy that someone from the Church is going to run it.
    20191104_144553.jpg 20191104_144624.jpg 20191104_144640.jpg 20191104_144732.jpg 20191104_144817.jpg
  2. HST4ME
    HST4ME Well-Known Member
    3,198
    5,332
    Nov 9, 2015
    Post it up om scream and fly
  3. NeedlesRat
    NeedlesRat Well-Known Member
    156
    64
    Oct 25, 2010
    Just curious, what was the boat doing with it 1” below? I have a 20 SST with a 280 offshore and 15” mid. My boat feels like the ass end is going going to let loose at about 80, so I’m wondering if that’s my issue. Possibly need to give it more jack or trim?
  4. Ragged Edge
    1,068
    779
    May 4, 2011
    The rules for the enduro require that we run the prop shaft no higher than 1" below the last 3' of the bottom of the boat. Handling is rock solid at 1" below unless it's over trimed. Do you run a Sportmaster or CLE case? The CLE case has a tendency to blow out at about 90 on some boats. The rear on ours (CLE currently) will start moving around (loose) at about 89 mph if over trimmed. And with a Stoker always more Jack and less trim.
  5. stoker2001
    stoker2001 Well-Known Member
    374
    232
    Apr 14, 2013
    I PMed you,this could benefit both of us as my Mirage runs case 1.5" plus above bottom
  6. Ragged Edge
    1,068
    779
    May 4, 2011
    Got your PM. Yes, this could work out well for both of us.
  7. NeedlesRat
    156
    64
    Oct 25, 2010
    It has the sportsmaster lower unit. It does the same thing that yours does. The rear end really gets moving around and then the boat starts to chime and get squirly.
  8. Ragged Edge
    1,068
    779
    May 4, 2011
    What prop are you running? It's not a cleaver is it? Could have too much transom lift or does it do this with every prop you have?
    I would suggest going higher with the jack plate and using neutral trim (engine pretty much square with the transom). Sorta like below. If you have cable steering torque steer is going to increase substantially but the loose feeling should go away.
  9. NeedlesRat
    156
    64
    Oct 25, 2010
    I am running a 28 mazco. Don’t know if it has had any work done to it. I run that prob most of the tome but I also have a 26 that I use here and there. Don’t recall if it does the same thing with the 26 since I use the 28 mostly. Hydraulic steering. I am going to try your trim suggestions. At what point can you tell that you’ve given it too much Jack?
  10. ONE-A-DAY
    ONE-A-DAY Well-Known Member
    12,620
    11,071
    May 21, 2010
    When it flips over backwards
    82daytona likes this.
  11. Ragged Edge
    1,068
    779
    May 4, 2011
    Too much jack and you run out of water pressure, so watch your gauge. You should be safe at 1" to 1 1/2" above the bottom with a sportmaster. I know guys who run higher than that and still have water pressure. As long as you do not use a lot of trim and are not running into a strong head wind it's unlikely that you'll blow it over, but when your trying to get the last couple of mph anything can happen so make sure you have safety gear on and the lanyard hooked up. As with any set up change take a little bit of time getting up to speed to get the feel of it.
  12. Ragged Edge
    1,068
    779
    May 4, 2011
    Also, I am guessing that this is a production hull not a race hull so it has the saddle fuel tanks correct? Weight distribution is important so make sure the fuel levels are the same in each tank. If you continue to have handling problems Alan Stoker is active on the Stoker Facebook page, I'm sure he would answer your questions.
  13. NeedlesRat
    156
    64
    Oct 25, 2010
    Thanks for the info. What prop do you run on your boat?
  14. Ragged Edge
    1,068
    779
    May 4, 2011
    The best handling prop we have is a 3 blade 26 Merc Lightening ET. These are great props but expensive, built for drag racing so they have thin blades and can be a little fragile. That said the 26 we have has about 500 hours on it. We also have a 3 blade 28 Hill Marine Eagle, which is very similar in design the the Merc ET but with stronger blades. Handles really good but we are still working with Hill Marine to get the most out of it.
  15. SKIA36
    SKIA36 Well-Known Member
    2,565
    700
    Apr 2, 2008
    The best blade for that boat was a 29 Mazco.
Share This Page
