- Dec 19, 2007
- 11,798
- 27,900
That’s one of many reasons to allow the pro’s to handle the glass work lolMan I get itchy just looking at that haha.
Any you suggest using? Like the cloth type stuff or whatMetal Polish works amazing on gel. Gives a deep wet look. Learned that from Kevin at KGM Boats
Gotcha I’ll go look tomorrow for some. Main thing right now is getting the face where the gauges are done as easiest time to do it is while they are out.Briwax Metal polish. I did the whole boat. 1 gallon will be more then enough. I did small hard to reach areas by hand, but used my variable speed 7" polisher with a buffing bonnet. Hard ass work, but well worth it!
Looks good! Did you use metal polish?
Loving your gauges and switch panel, they look great!
I went with a glass dash on my boat but if I had gone traditional gauges, my dash would hopefully look like yours!
I most commonly use the delco weather packs for ease and fact i can get most of it locally. Would like to figure out the deutch connectors but tmi they only go to a 4 prong right?if you ever need any of the deutch connectors or pins let me know I have full supply of that stuff
Biggest issue was simply the fact that who ever was wiring these Boats was not a wire guy, he was a connector guy lol. The helm had “1” power wire feeding in then split then split then split with butt connectors as well where it went into the switch panel was All powers and grounds just leap frogged from pin to pin. With the utilization of that K-Four 12 pole Power and ground distribution block i now have the one + & - going to that then each pole throughout has its own +&- as well fused now. Was completely shocked the whole helm was powered and fused by one, yes One 40a fuse. Yea would have been a serious meltdown before that blew now all but ign fuel switch and hatch (15a on those) are on separate 5a will see that they all flow fine as i don’t have the schematic for each i was going to go 10a but said F’it I’ll start low low and be safe.Cant wait to see your wiring all done. This is the only area left on my boat that I never touched. Re-rigged every other inch already. You have now forced my hand and I will be copying you once my snowbirds exit my house.
and NO butt connections lol. While rewiring the sensors etc a few had to get a fresh run from the rear as there were butt connections on those runs as well. If a wire is 1/2” too short on a 10’ run I’ll still do a new run I’d be more ok with them eliminating those from the stores than to see a group of liberals at the bottom of the sea!I have done this already in my engine compartment. That was a rats nest of wires and impossible to trace. Any issue with a piece of equipment and I was dead in the water. Each piece is now on its own fuse with the shortest run of wire possible and the right size gauge.
Dash is looking great dude!!! I like it.
I need to pull my dana switch panels out and figure out some of my switches. I have 2 acc switches that do nothing, but my stereo is wired off the port engine key, which runs the hour meter.
Thanks for keeping this thread goin!
Looks great. I know who rigged our boats. The first 4 where done by Rusty, now Ultra when he had his shop in Elsinore. Yours and mine are in that group. The last few where done by Lightning in Riverside. So many great features on these boats. The gelcoat quality, lay up schedule. Boats are solid, but these last few details always drove me nuts and I watched mine get built. If I was not so damn excited to get on the water I would have pressed the issue before delivery.
Ya wanna come over and do the wiring on my dash?Ok i kinda summed up the major issue with the posts with WerHull another Orion brother, the issue was lack of skill imho and a mentality of “who cares it works and isn’t seen anyway”
But the single 10g power wire going into the helm was then split to numerous connections via butt connectors and had a single inline 30a fuse before first split. It was just a rat nest plain and simple.
View attachment 608492 View attachment 608493
Got a 12 fused link distribution block from K-four which come to find out is actually manufactured by BlueSea. Knowing i was going to run individual power and ground to each of the 8 switches i basically just built an extra long harness while on the bench to go to each of the switches View attachment 608494 View attachment 608495 View attachment 608496 View attachment 608497 View attachment 608498 View attachment 608499 View attachment 608500
I need to get in and finish wiring the kill switch and rerunning the power and ground for my interior leds then i can add a few more zip ties but basically i am calling it done now!! View attachment 608501
And well yea i am just totally infatuated with Blue leds and so so so stoked with how these Livorsi’s shine View attachment 608502 View attachment 608503
Sent from my SM-G900T using Tapatalk
When it comes to the wiring, I'm pretty much one of those , hey it works, let's go to the lake.Lol depending on what All needs done it’s not all that hard but can’t travel, nothing worse then getting somewhere then realizing you need another tool or ..... but i am always game to do side work and know I’m cheaper than any shop. May not be as good as most shops but then i could also be better than a lot of shops lol.
No I have them up to 8 i think then they go big round ones way past 8I most commonly use the delco weather packs for ease and fact i can get most of it locally. Would like to figure out the deutch connectors but tmi they only go to a 4 prong right?
Ill just give you the keys to the Havasu house, let me know when you are done with my boat and anything else in the garage. Fridge is full of beer and soda, bar is also stockedLol depending on what All needs done it’s not all that hard but can’t travel, nothing worse then getting somewhere then realizing you need another tool or ..... but i am always game to do side work and know I’m cheaper than any shop. May not be as good as most shops but then i could also be better than a lot of shops lol.
