- Sep 13, 2007
- 104,474
- 85,779
Sorry for the delay, had a computer issue that I was battling yesterday, and most of today.. Finally got it fixed. (Blue Screen Blues, and it wouldn't open a PDF)
DIVISION 1: "FACTORY INBOARD SKI & PERFORMANCE"
New for 2015, Division 1 is now a bracket class intended for both pleasure and performance boats that run in the 55-75 mph range. The maximum speed for this division is limited to an 11-minute lap time over the 12-mile course. This equates to an average speed of around 65.5 mph. If a Division 1 boat records a lap faster than 11:00 minutes, then the current lap will not count as completed. If a driver has 3 or more violations and the referee deems him unsafe a black flag will be shown to the driver and he will be required to trailer the boat and face penalty.
HULL: Any type of boat is allowed. Minimum length is 16 feet, measured from bow to transom of the hull (excluding external engine set back). Maximum length is 22 feet. Weight is unrestricted unless a boat is deemed too heavy, causing large wakes.
ENGINE: Inboard internal combustion only. No Turbine.
DRIVE: No surface drive allowed.
DIVISION 2: "FACTORY OUTBOARD BASS & PERFORMANCE"
New for 2015, Division 2 is now a bracket class intended for both pleasure and performance boats that run in the 55-75 mph range. The maximum speed for this division is limited to an 11-minute lap time over the 12-mile course. This equates to an average speed of around 65.5 mph. If a Division 2 boat records a lap faster than 11:00 minutes, then the current lap will not count as completed. If a driver has 3 or more violations and the referee deems him unsafe a black flag will be shown to the driver and he will be required to trailer the boat and face penalty.
ENGINE: Outboard only.
DRIVE: Unrestricted.
DIVISION 3: "SMALL BLOCK V-DRIVE/ N.A. JET"
A) V-DRIVE
HULL: Flat bottom or v-bottom boats with open cockpit are allowed. Minimum length is 16 feet, measured from bow to transom of the hull. Maximum length is 22 feet.
ENGINE: Naturally aspirated production made small block.
B) JET
HULL: Flat bottom, v-bottom, Mod-VP boats with open cockpits allowed. Minimum length is 16 feet, measured from bow to transom of the hull. Maximum length is 22 feet.
ENGINE: Naturally aspirated internal combustion only.
DRIVE REQUIREMENTS: A rudder must be in place that extends not less than 4? below the bottom of the jet nozzle and must not be less than 4? in length. Nozzle adjustment may be used but limited to 5 degrees above planning surface and brought down when entering and exiting the pits. Upon departure from pit row, the nozzle shall remain in the full down position until safely on the race course. (SAFETY ITEM: violation subject to disqualification.)
DIVISION 4: "OUTBOARD RUNNABOUT"
HULL: V-bottom, flat-bottom, and Mod VP (with the center pod lower than the sponsons at the transom) boats with open cockpits are allowed. True tunnels are NOT allowed. Minimum length is 17' 9", measured from bow to transom of the hull (excluding external engine set back). Maximum length is 23 feet. Minimum dry weight is 1,325 lbs. (without driver and fuel). If fuel is in boat it will be weighed at 6.7 lbs. per gallon.
Ballast added to boats shall be securely anchored in a manner to prevent it from detaching while underway. No single piece of ballast shall weigh more than 50 lbs. Total battery weight exceeding 120 lbs. is NOT allowed. All areas of the boat must be available for inspection.
ENGINE: All engines must be naturally aspirated (no EFI, DFI, turbo chargers, or supercharger) and of a production design. Maximum displacement is 130 cu. (engines may not be modified to reduce their displacement in order to comply with this rule). Maximum carburetor size is 1.327 inches measured at the venturi.
Ports may be modified but shall remain in their original location. Additional ports may NOT be added to any cylinder. Finger porting is NOT allowed. "Behind-the-liner" and Bridgeport exhaust engines may be run in Division B with one (1) inch venturi carburetors.
V-4 and inline 6 cylinder engines (referred to as ALTERNATE engines) shall be exempt from all of the above rules except for the 130 cu. in. max rule.
Mercury V-6 engines shall have a cylinder head volume of no less than 26 CCs measured with a surface gap spark plug installed. Head gaskets must be used and must measure no less than .030 of an inch at the crush ring when removed for inspection.
Blocks and pistons may not be modified in any manner so as to increase the compression ratio. Alternate engines may use any cylinder head/piston configuration. The top of the piston may protrude beyond the deck of the block no more than .010 of an inch to provide for deck "clean-up" purposes.
All critical or performance related parts/components installed on Mercury V6 engines (except pistons, rings, bearings, reeds, replacement electronics and sealing components) shall be OEM parts. Parts may be exchanged from other years HP models as long as they are OEM. Alternate engines may use components from any source.
Unless specifically forbidden in above rules, engines may be modified in any way.
DRIVE: Mercury V-6 lower units must be of production shifter type with working forward, neutral & reverse from the driver's seat and must measure at least 4 3/4 inches in diameter just forward of the propeller. No XR6 lowers units allowed. Water pick-ups must be on the lower unit.
All lower units must be run with the center of the prop shaft no higher than 1/2" inch below the last 3 feet of running surface. The prop shaft must be parallel to the running surface during measurement. Alternate engines such as Evinrude, Johnson, and Mercury inline-6 cylinders may run the original factory installed gear case with the prop shaft 1⁄2" inch below the last 3 feet of the running surface. The prop shaft must be parallel to the running surface at the time of measurement.
Engine jack plates will be inspected for safety. They shall be disabled and through-bolted with a 3/8 inch Grade 8 or better self-locking nut and must be MARKED by inspector prior to racing.
DIVISION 5: "F-2 OUTBOARD SKI RACER"
HULL: F-2 ski race hulls shall be a minimum of 5.48 meters (18 feet) and a maximum of 6.5 (21.35 feet) meters. Weight is unrestricted.
ENGINE: Engines limited to a maximum of 3.2 Liter outboards only and shall be stock as listed/advertised in basic catalog. No factory racing engines or de-tuned racing engines. Engine capacity limited to a maximum of 300 horsepower as measured at the prop shaft. Exhaust system must be stock.
DRIVE: Standard lower unit only that is part of the original engine package. All motors must have an operational forward-neutral-reverse (must be operational while the boat is running). No modified lower units (i.e., no "quick feet"). No mechanical means of height adjustment for engine (no "jacking mechanisms"). To restrict the height a single outboard is mounted on the transom with the outboard trimmed so the prop shaft is parallel to the bottom of the hull, the center of the prop shaft will be no higher than the bottom of the hull (plank or vee). No removal of metal from the skeg and no modification to the water intake. No aftermarket nose cones allowed. All nose cones to be standard as part of original engine package.
DIVISION 6: "N.A. V-DRIVE/ FORCED INDUCTION JET"
A) V-DRIVE:
HULL: V-bottom, and flat-bottom boats with open cockpits are allowed. Minimum length is 17 feet. Maximum length is 22 feet. Weight is unrestricted.
ENGINE: Unlimited, naturally aspirated. Unrestricted Diesel power. No turbines.
DRIVE: V-drive only.
B) JET:
HULL: V-bottom, flat bottom, mod-vp boats with open cockpits are allowed. Minimum length is 17 feet. Maximum length is 22 feet. Weight is unrestricted.
ENGINE: Unlimited internal combustion. No turbine power.
DIVISION 7: "GRAND NATIONALS"
HULL: V-bottom, flat-bottom boats with open cockpits are allowed. Minimum length is 17 feet. Weight unrestricted.
ENGINE: Super charged engines limited to 473 cubic inch. Naturally aspirated engines limited to 525 cubic inch.
Blower drives restricted per APBA rules. Diesel power unrestricted.
NOTE: Teams competing for National High Points will be permitted to run faster than their qualifying time but will no longer be able to compete for the overall. Current APBA Grand National rules apply.
DIVISION 8: "GN77/Justified/BloodShot and others"
A) V-DRIVE
HULL: V-bottom, flat bottom, Mod VP, and tunnel boats with open cockpits are allowed. Minimum length is 16 feet.
Maximum length is 23 feet. Weight is unrestricted. No surface drives.
ENGINE: Unrestricted. Tunnel or Mod-VP restricted to natural aspiration only. No turbine power
B) OUTDRIVE
HULL: V-bottom, flat bottom, Mod-VP, tunnel.
ENGINE: Naturally aspirated production style small block.
DIVISION 9: "SINGLE ENGINE OUTBOARDS"
HULL: V-bottom, flat-bottom, or Mod VP (with the center pod lower than the sponsons at the transom) boats with open cockpits are allowed. True tunnels are NOT allowed. Minimum length is 17' 9" measured from bow to transom of the hull (excluding external engine set back). Maximum length is 23 feet. Minimum dry weight is 1,500 lbs. (without driver and fuel). If fuel is in boat it will be weighed at 6.7 lbs. per gallon.
Ballast added to boats shall be securely anchored in a manner to prevent it from detaching while underway. Total battery weight exceeding 120 lbs. is NOT allowed. All areas of the boat must be available for inspection.
ENGINE: Naturally aspirated outboards are allowed. No turbo chargers or superchargers.
MERCURY 2.5 LITER AND OTHER ?BEHIND THE LINER? ENGINES: Are allowed but must have a cylinder head volume of no less than 32 CCs measured with a surface gap spark plug installed. Head gaskets of must be used and must measure no less than .035 of an inch at the crush ring when removed for inspection. O-ring heads and other non-production style gasket heads are allowed but must have a cylinder head volume of no less than 37 CCs measured with a surface gap spark plug installed.
GREEN ENGINES: Including Mercury OptiMax, Evinrude E-Tec, Mercury Verado, Yamaha V-MAX, & Suzuki DF are allowed but must remain as delivered from the engine manufacturer except for external modifications only which are limited to a ECU reprogramming, throttle body modifications, balanced aluminum flywheels (excessive lightening is not permitted) and cowling modifications.
DRIVE REQUIRMENTS:
MERCURY V-6 LOWER UNIT: Must be of production shifter type with working forward, neutral & reverse from the driver's seat and must measure at least 4 3/4 inches in diameter just forward of the propeller. No XR6 lowers units allowed. Water pick-ups must be on the lower unit.
MODIFIED LOWER UNIT: Must be run with the center of the prop shaft no higher than 1 inch below the last 3 feet of running surface. The prop shaft must be parallel to the running surface during measurement.
GREEN MOTOR LOWER UNITS: Must remain as delivered from the manufacturer and with the center of the prop shaft no higher than 1/2 inch below the last 3 feet of running surface. The prop shaft must be parallel to the running surface during measurement.
DIVISION 10: "UNLIMITED OUTBOARD"
HULL: Unrestricted. Minimum length is 18 feet. Maximum length is 22 feet. Weight is unrestricted.
NOTE: In an effort to maintain safety the class will be restricted to a 100mph average lap time.
DIVISION 11: "UNLIMITED INBOARD"
HULL: Unrestricted. Minimum length is 20 feet. Maximum length is 22 feet. Weight is unrestricted.
ENGINE: Unrestricted internal combustion. No turbine power.
DRIVE: No surface drives.
A) V-DRIVE
B) JET
A) V-DRIVE:
B) JET:
A) V-DRIVE
B) OUTDRIVE
DRIVE REQUIRMENTS:
