2018 Silverado
jholley
Your RDP Connection To Selman Chevrolet!!!
2018 Silverado Crew Cab LT
MSRP $47,295.00
RDP Price $41,384.00
GM Rebate $1,500.00
GM Bonus cash $3,500.00
GM DPA $1,000.00 Must finance with GM
*Net price before T.L $35,384.00
Window Sticker
2018 Chevrolet Silverado 1500
Crew Cab
Engine
5.3L EcoTec3 V8 engine
Transmission
Automatic
Trim
LT
Silver Ice Metallic
Pricing
Destination Charge $1,495.00
Installed Options
  • Engine, 5.3L EcoTec3 V8 with Active Fuel Management, Direct Injection and Variable Valve Timing $1,195.00
  • Wheels, 20" x 9" (50.8 cm x 22.9 cm) polished-aluminum $1,595.00
  • All Star Edition $2,275.00
  • Trailer brake controller, integrated $275.00
  • LPO, Polished exhaust tip $140.00
  • Bed Liner, Spray-on, Pickup box bed liner $495.00
  • LED Lighting, cargo box $125.00
  • ALL STAR EDITION PACKAGE DISCOUNT -$750.00
Total Options $5,350.00
MSRP* $47,295.00
Silverado 1500 Standard Equipment**
Interior
  • Front 40/20/40 split-bench seat with under seat storage
    • Seats 3
    • Driver and front passenger seatbacks recline
    • Lockable storage compartment in seat cushion
    • Head restraints at the outboard seating positions
    • Center seatback that doubles as a fold-down armrest with storage
    • Driver lumbar with manual adjust
    • Storage pockets
  • Rear 60/40 split folding bench seat
    • Seats 3
    • Seats fold up
    • Can fold one or both sides up
    • Includes child seat top tether anchor
    • Adds cargo and passenger carrying versatility to your vehicle
  • Floor carpeting
    • With rubberized vinyl floor mats
  • Leather-wrapped steering wheel with cruise and audio controls
  • Manual tilt steering column
    • Allows the driver to adjust the steering wheel up or down manually
    • Offers enhanced driver comfort while on the road and while entering or exiting the vehicle
  • Steering wheel audio controls
    • Easily operate the audio system and manage most search functions of compatible, connected MP3 players and other media devices
  • Instrumentation, 6-gauge cluster featuring speedometer, fuel level, engine temperature, tachometer, voltage and oil pressure
  • 4.2" diagonal multi-color Driver Information Center
    • Provides key vehicle information such as average vehicle speed, fuel range, average fuel economy, tire pressure, oil life, trip odometer and warnings
  • Power windows
    • One-touch Express-Down for all, Express-Up for driver
  • Power door locks
    • Programmable
    • Lock out protection
    • Allows you to lock and unlock doors easily whether it’s from the driver or front passenger seat or from outside using the key fob
    • Lockout protection helps you avoid locking keys in the vehicle
  • Remote Keyless Entry
    • Allows you to lock and unlock doors of the vehicle with the key fob
    • 2 transmitters
    • Includes remote locking tailgate
  • Cruise Control
    • Maintain a steady speed while driving
    • To enhance your safety, cruise control automatically disengages when the vehicle's traction control system needs to limit wheelspin on slippery surfaces or when the StabiliTrak® stability control system detects an oncoming skid
    • Set and resume speed functions
    • Steering-wheel mounted controls to easily maintain and manage cruising speed
  • Air conditioning
    • Cools and dehumidifies the air inside the vehicle
  • Illuminated visor vanity mirrors
    • Driver and front passenger mirrors are color-keyed and padded with cloth trim
    • Covered mirrors are included for both the driver and front passenger
    • Pull down to block the sun's glare
  • Front passenger assist handle
    • Located on A-pillar
Mechanical
  • Pickup box
    • Roll-formed high-strength steel
  • 4.3L EcoTec3 V6 engine
    • 285 hp @ 5300 rpm
    • 305 lb-ft of torque @ 3900 rpm
    • Aluminum block
    • Active Fuel Management
    • Direct Injection
    • Variable Valve Timing
    • FlexFuel capable
  • 6-speed automatic transmission
    • Tow/Haul mode raises transmission upshift points to provide more power to accelerate with a trailer or heavy load and raises downshift points to use engine compression to help slow the truck instead of merely braking
    • Powertrain Grade Braking automatically uses the engine and transmission to slow the truck to maintain desired speeds when driving downhill which helps reduces brake wear and increases vehicle control
    • Cruise Grade Braking downshifts automatically to slow the truck as it drives downhill if it exceeds the cruise set speed by a certain amount
  • 3.23 rear axle ratio
  • 6900 lbs. GVWR
    • When properly equipped; includes weight of vehicle, passengers, cargo and equipment
  • Rear wheel drive
  • External engine oil cooler
    • Heavy-duty air-to-oil cooler
  • Heavy-duty battery with 730 cold-cranking amps
    • 70 Amp-hr
    • Maintenance-free with rundown protection and retained accessory power
  • 150 amp alternator
  • Fully boxed frame
    • Hydroformed front section
    • High-strength steel
  • Steering, Electric Power Steering (EPS) assist, rack-and-pinion
  • 4-wheel antilock disc brakes
    • DuraLife brake rotors have better resistance to corrosion to increase rotor life, minimize brake pulsation, and improve aesthetic appearance
    • Brake system features a corrosion-fighting process called "Ferritic Nitro Carburizing" which can double rotor life expectancy and reduce or minimize rust
  • Capless fuel fill
  • Exhaust, aluminized stainless-steel muffler and tailpipe
Entertainment
  • Chevrolet MyLink® audio system with 8" Diagonal Color touch-screen
    • AM/FM/SiriusXM® Satellite Radio, with 3 trial months
    • HD Radio capability
    • 8" diagonal high-resolution, color touch-screen integrated with the 4.2" diagonal display to help minimize distractions
    • Gesture recognition allows users to swipe, click, drag and fling to navigate through the touchscreen menus
    • Bluethooth® streaming audio for music and select phones, and hands-free smartphone integration for Pandora® Internet Radio
    • Apple CarPlay™ and Android Auto™ capability for compatible phones
    • Voice-activated technology for radio and phone
    • USB port(s) to play stored audio files through your vehicles audio system
    • Auxiliary jack for connecting portable media devices
  • Single-slot CD/MP3 player
    • Offers a choice of media so you can play your favorite music through your truck's audio system
  • HD radio
    • Provides consumers with additional channels known as HD2, HD3 and HD4
    • Transmits Program Service Data, such as long titles and artist information
  • SiriusXM Satellite Radio
    • Welcome to the world of SiriusXM®
    • Enjoy your 3-month trial subscription to the All Access package with over 150 channels including commercial-free music, plus sports, exclusive talk, entertainment and news
    • Plus, listen on the app and online — it’s included with All Access, so you’ll hear the best SiriusXM has to offer, anywhere life takes you
  • 6-speaker audio system
    • 6 speakers
    • Positioned throughout the cabin for great sound and an enjoyable listening experience
  • Bluetooth®
    • Pair your mobile phone to your vehicle’s infotainment system
    • Place and receive hand-free phone calls
    • Store your phone’s contact list in the system to place an outgoing call quickly using the touch-screen display or voice command system
    • With streaming audio capability you can listen to files stored on your phone or Bluetooth digital media device
  • Built-in 4G LTE Wi-Fi® hotspot
    • A strong connection to the Internet for up to 7 devices
    • Includes Data Trial for 1 month or 3GB (whichever comes first)
Safety-Interior
  • 6 air bags
    • Front air bags work with the safety belt system to help reduce the risk of injury to the driver and right-front passenger if involved in a moderate to severe frontal impact
    • Seat-mounted side-impact air bags for front outboard seating positions deploy from the seats and help provide additional protection when your vehicle is struck from the side
    • Head-curtain air bags help reduce the risk of head and neck injuries to occupants seated in the outboard seating positions in side-impact collisions and rollovers
    • Passenger Sensing System automatically switches the right-front passenger seat frontal air bag on or off
  • OnStar®
    • OnStar® and Chevrolet Connected Services capable; receive 1 month of Chevrolet Connected Services and 1 month of OnStar Safety & Security Coverage, plus 3GB/1 month of data, whichever comes first. See your dealer for details
  • Chevrolet Connected Access with 10 years of standard connectivity
    • Enables select services such as Vehicle Diagnostics and Dealer Maintenance Notifications and more
  • Rear Vision Camera
    • When in Reverse, provides the driver a view of the scene directly behind the vehicle on the Infotainment screen to help the driver park and avoid crashing into nearby objects during low-speed maneuvering
    • Dynamic guidelines laid over the display image assist in parking maneuvers by showing the vehicle's path and available space
    • Tailgate must be in the raised position for the Rear Vision Camera to operate properly
  • Teen Driver
    • This configurable feature lets you activate customizable vehicle settings associated with a key fob to help encourage safe driving behavior
    • It can limit certain vehicle features, and automatically turns on certain safety systems if vehicle is equipped
    • An in-vehicle report card gives you information on your teen's driving habits and helps you to continue to coach your new driver
  • Tire Pressure Monitoring System
    • Monitors the pressure in each tire and alerts you if there is a low-pressure condition in one or more of the tires
    • Properly inflate tires to help optimize your vehicle’s ride, handling and efficiency
    • Includes tire fill alert
Safety-Mechanical
  • StabiliTrak® electronic stability control system
    • Automatically helps enhance control, particularly during emergency maneuvers, by adjusting the brakes and engine torque to keep you on your intended path
    • With Rollover Mitigation
    • Activates when vehicle sensors detect a difference between the driver's intended path and the direction the vehicle is actually travelling
    • Includes Trailer Sway Control
    • Hill start assist
Exterior
  • 17" x 8" bright machined aluminum wheels
  • 17" P255/70R17 all-season, blackwall tires
  • 17" full-size spare steel wheel
  • 17" P255/70/R17 all-season, blackwall spare tire
  • Spare tire carrier lock
    • Helps keep spare tire secure
    • Utilizes the same key as the door and ignition
  • Chrome front bumper
  • Chrome rear bumper
  • Cab-mounted cargo area lamps
    • With switch on center switch bank
    • Illuminates cargo box area
  • CornerStep rear bumper
    • Helps make it easier to get into and out of the pickup bed, even with the tailgate open
    • Located at each end of the rear bumper
    • Textured step pads to help provide secure footing
  • Body-color body-side moldings
  • Rear wheelhouse liners
    • Help protect your truck's rear wheelhouse area from damage caused by dirt, rocks, mud, road salt and the weather
  • Chrome grille surround
  • Active Aero Shutters, front
  • High-Intensity Discharge (HID) projector-beam headlamps with LED signature lighting
    • Provide a bright, intense beam of light to help illuminate road signs and highway
    • Projector-beam headlamps with signature LED lighting
  • Outside, heated power-adjustable mirrors
    • Includes driver's side spotter mirror
  • Body-color mirror caps
  • Deep-tinted rear glass
    • Provides added protection from sun and glare
  • Body-color door handles
  • Tailgate and bed rails protection cap
  • Remote Locking Tailgate
    • A remote tailgate lock and unlock feature located on the key fob
    • Manual unlock is still available using the same key as the ignition and door
  • EZ-Lift and Lower tailgate
    • Raise and lowers the tailgate with reduced effort thanks to the assist of an internal torsion bar
    • Tailgate locks and unlocks with the same key as the ignition and door
Safety-Exterior
  • Daytime Running Lamps
    • Illuminated when your vehicle is running and the headlamps are off
    • Makes your vehicle more visible to oncoming traffic
    • Can help reduce the risk of collision
Warranty
  • Basic: 3 Years/36,000 Miles
  • Corrosion: 3 Years/36,000 Miles Rust-Through 6 Years/100,000 Miles
  • Drivetrain: 5 Years/60,000 Miles Qualified Fleet Purchases: 5 Years/100,000 Miles
  • Maintenance: 2 Years/24,000 Miles 2 Visits
  • Roadside Assistance: 5 Years/60,000 Miles Qualified Fleet Purchases: 5 Years/100,000 Miles
While every effort is made to assure this information to be accurate, variations in the manufacturing process, dealer installed accessories and mileage figures may cause this window sticker display to vary from that on the vehicle. Check with your dealer for complete information.
Instigator
Just Livin up to My Name
Nice truck and great deal but if you can get it with 2 more rear wheels and the Duramax and Allison at that price, I'll be the 1st one in line!!:D
whyyy couldn't be a 2500?
He barely has any 2018s in 2500. Discount only applies on them if you finance with there bank. Better off with a 2019 2500 how you like it.
cxr
LOl I need the discount already told myself im not paying 60K for a new truck :)
pull-on
Roofers do it on top.
When can we see pricing on the new 2019 medium dutys? 4500, 5500, and 6500??
