23 Daytona Renovation.
MK1MOD0
Well Gents. as some of you know, I picked up a 1988 23 Daytona in Florida last week. Today’s the day I started to do the renovations she needs for the summer. I’m not looking to do a complete restoration. This will be a lot simpler, and a much smaller scale than the Stress Eliminator. This will be all about getting the boat water ready, reliable and looking good. The boat came with twin Johnson 225 HO motors which actually make about 250hp. It has nose cones installed and the drives are even with the bottom at this point. here are my plans
1) replace some soft wood on the floor. The areas are mostly where the seats had been bolted in.
2) build a new rear storage area and detail the bilge ect. ( to include cleaning up the wiring.).
3) install new seats. I’m going for a pure-hot rod. 4 race seats and not much else. No vinyl or other upholstery. I’ll be adding sea deck instead of carpeting. As for music, I’ll be adding a sound bar for tunes. Lite weight and simple. ( I love music, so tunes are essential when floating )
4) repaint the motors and brackets.
5) paint restoration. There are a number of spots that need attention. Then after I repair those areas, I will wet sand and clear coat the boat
6) I’ll also need to do a full tune up. Impellar, plugs, drive oil ect.
Headless hula
There’s an all white California deck that’s got a fresh transom that just might beat you to the water lurking up behind the cheddar curtain. 🤓
you drove past my place in Florida a couple days ago. Good luck with your project. 🤘🏼🤘🏼
MK1MOD0
Oh hell yes ! I’m hoping to make it to the Lower river run mid June. So I’m going to be a busy boy ! Damn fine looking transom She’s sportin .
Headless hula
Get to work. I’ll be reading your updates. Probably won’t be posting for a while. 😬
coolchange
Lower level functionary
Be interesting to see how you pull off number three.
stingray11
Lose the vro systems, Run the water separating fuel filters that are in there, And a electric fuel pumpFor each motor at 5-6 psi max for those carbs. Also check the Water separating fuel filter housing where the rubber gasket sits for Corrosion. I can almost guarantee it will have corrosion on it.
MK1MOD0
These are the seats I’ll be running. Remember, this boat is just a hot rod, not a family cruiser for me. I’m taking a LOT of weight Out. I’ll install EVA flooring as well.
PS. They are only 19lbs each.
MK1MOD0
Im totally divided on this. It’s a 50/50 debates as far as I can tell. The previous owner had new VRO pumps installed after he purchased the boat. it was premix when he got it.
MK1MOD0
For the rear storage / hatch, I’ll be using EXTREN. It’s a high strength fiberglass panel, that’s liter than plywood and stronger. Only problem..... it’s expensive. It will have to support weight to wal across, so going to use 1/2 inch. Will see if 1/4 inch will work with underbracing
HydroSkreamin
Stress Eliminator
Do you have any fiberglass experience? That could be way lighter and cheaper if you used 1” core foam and 2-3 layers of 1808.
Three layers of 1808 is about 1/8” thick and super strong due to having the layers 1” apart. You’ll be defeating your purpose if you do 1/2 EXTREN. It’ll be strong, but the thickness will defeat your intention of light weight. Also, how do you plan on doing the joint for strength? Just trying to see your design.
For reference, 5# core foam is 5#/cubic foot. So potentially, your entire hatch could be less than 10 lbs of foam, and about 30 lbs of fiberglass. Obviously foam and vinyl would add extra weight as well, but you could finish off the fiberglass and gel or paint it to save weight.
I’m looking forward to seeing your progress!
MK1MOD0
Not a ton of experience for sure. And open to recommendations. The hatch will be painted. No vinyl in the boat at all. So I’m trying to keep a good surface to paint. The hatch will simply be a flat piece, so was trying to keep it simple. Hell. Even a finished wood piece could work. I’m not familiar with 1808. Is it solid fiberglass sheet?
The other simple way could be a finished sheet of Birch. 5/8”. Then just a few under supports to add rigidity for walking. Then prime and paint. ????? I’m certainly no carpenter. Lol.
Shlbyntro
Ultra Conservative
It makes me happy that you're keeping the Johnsons. Im A suckered for nostalgia. One of these days I'll find my johnson V8 project.... id love to go for a ride in this thing when its done
When were the "new" VROs installed they switched them to a fixed ratio pump about 15ish years ago and are far more dependable than the oroginals ever were.
That being said I still believe in premixing and im not a fan of puting an electric pump on these engines, I'd keep the vros plumbed and running as normal and also mix your fuel tank at 100:1.
I might be a little bit of an OMC nut. To my knowledge, there isn't a cure for my disease yet
MK1MOD0
I Believe the previous owner purchased the boat around 2016-2017. So the pumps were installed after that. I probably need to do some investigation on the pump model numbers just to be sure. The 100:1 idea is pretty good. May give an added level of safety.
MK1MOD0
I finished up the floor today. It actually came out looking pretty damn good I must say. There are a couple bubbles, but nothing I can’t take care of in a short time. Next on the list will be to start to clean and detail the rest of the cockpit and bilge area, includi all the spaghetti wiring. After the seats arrive, ill be able do some measurements, and begin to build a new center console.
MK1MOD0
Finally got to work on the boat again yesterday. Started to straighten rats Nest of wiring, and some minor fiberglass work inside the cockpit area. Also started to clean up the fuel tanks , because they will be exposed and were pretty dull and scuffed on the outside. Today I want to fiberglass the holes in the cockpit area that were part of the mounting of the interior and get it primed. Lots of small stuff right now, but it needs to be done , in order to look good. Time consuming but worth it.
I was able to get most of all the parts I needed. Got the impeller kits, new fuel filters, and gear lube. 3 new auto bilge pumps and thru hull fittings. I also ordered a swim step from Eddie Marine.
MK1MOD0
I was able to get a lot accomplished this week. Most all of the fiberglass work is completed. Including the holes in the cockpit gunwale where all the interior was mounted. I also was able to clean up the wiring mess. It’s not perfect under the dash. But I can work on that later. I re-routed the steering hoses and cleaned all the bilge wiring up. It’s amazing what some zip ties and patience will do. Next week I’ll start to work on the paint. Basically, I’ll work on the major blemishes, then wet sand the entire boat and clear coat it. It will be more durable and add some extra shine ! Here is a before and after of the bilge. And that’s a wrap for this week. Going to take the weekend off and just enjoy this holiday.
