26 Daytona 1000HP, IMCO Ext Box..going with a IMCO SCX..but what lower & gear ratio?
mgh
Going to be going with the IMCO SCX Upper, but not sure what lower and gear ratio? Boat dyno'd at 1000hp/1000tq
IMCO Neutral Extension Box
1) IMCO SCX Upper, SCX Lower (heard SCX Lower scrubs speed, maybe changes boat handling?)
2) IMCO SCX Upper, SC Lower (basically same setup as a BMAX...larger upper gear set, XR lower gear set)...
3) IMCO SCX Upper, Dual Downshaft Lower
Going to do the 1 7/16 propshaft upgrade...unless anyone says not too?
Thanks for all the help
IMCO will probably give you some solid advice if you call and talk with them. They have excellent customer service.
HALLETT BOY
I’m guessing SCX upper with new dual shaft lower
Water rod
The set-up is huge. If your gonna run an SCX lower you will need to surface it. If not the boat will slow down. Where is your X dimension? The SCX upper with downshaft lower is a good solid option. Stay away from the SC lower. They don't take 1000+ hp and torque well. Gear ratio generally want 1.34 with bigger HP so you don't run out of props.
mgh
Spoke to fred @ imco the other day , said scx/sc combo.Going to call again tomorrow to double check before ordering. Would like to find someone who has a combo they are happy with
mgh
right now my Bmax is 1/2 inch @ prop shaft center lower than hull
zx14
The Skipper
I have about 40 hours on Sc lower scx upper, about a inch above the sponsons. ITS standoff.
ToMorrow44
27 Advantage TCM 800efi
If you haven’t already, ask this question on the Eliminator Boat Owners Facebook group. There’s a wealth of info there 👍🏻
zx14
The Skipper
what hp, gear ratio, lower is -2? Prop? Thnx
1.34 hp close to yours, heavily worked BBlades 28” bravo, at 29” now. Gets me to 6300 rpm. With the XR, I’d run my 32” bravo, BBlades brought down to 31”. The XR was a inch below. The scx upper did take some mph, even with the higher X.
mgh
Curious if anyone is running the 1.24 imco ratio overall?
seems like majority is 1.34
Boat 405
1.34 gear ratio. Scx upper sc lower.
Boat 405
is that what your running? What prop, hp, and mph/slip do you see..thanks
No. I’m running 860 hp. 800 ft lbs normally aspirated 582. 1.5 ratio scx upper. Sc lower -2. Stock 30 p bravo spins 6300 rpm. 109 mph in a 25 daytona. Imco extension neutral box.
You’ll be in the upper teens with 1000 hp/ft lbs. tried the DD. Boat didn’t like it. Went back to the SC. I’m assuming blown deal. 1.34 ratio with a 30 or 32 will probably be your go to
mgh
yes, blown 565, 14-71 blower tuned for 93 octane ...thinking 1.34 is what I’m leaning towards. the 30p
assume the 1 7/16 prop shaft? Any reason not to do this and go 1 1/4 prop shaft? Thanks
She's Mine
I'm running the SCX upper and SCX blueprinted lower. I went with dependability over speed. Yes, at times I wish I had the SC lower but I've been running this setup for a few years without issue. 1100HP 1.34 gears and a worked Bravo 35p. To be honest it all depends on what you want to do. I know plenty of people that run the SCX/ SC setup and have broken and I know people that run the same setup and it holds together. Just depends on how hard you are on the throttle.
mgh
i would say i am a sensible driver, has anyone used the 1.25 gear ratio and had success?
mgh
1.35, with the 1.50 we were hitting the rev limiter with a 34 in the winter time
i see the 1.25 gear ratio as an option? would this help...what would the trade off be? i see imco offers 1.25, 1.34, 1.5
ONE-A-DAY
the 1.34 allowed us to go down a prop size, i considered things resolved
Boat 405
I’d get the 1 7/16 shaft. Opens up availability to props
