27' Speedster Full Composite build 1100HP LS
Eliminator Boats
The owner of this build is no other than Mike Fountain of Fountain Racing Engines (FRE) https://www.facebook.com/fountainraceengines/ out of Sarasota, Fl. featuring one of his unique V8 engines that's far above any typical high performance boat engine. This will be an extremely one of a kind build.
The 27 foot catamaran will be built out of Carbon/Kevlar with Coosa polyurethane stringers, bulkheads, and floors. Will feature honeycomb carbon inlays on the deck and sides of the hull. The interior will have an east coast flair with full composite construction.
Eliminator Boats
Honeycomb inlay goes in the mold over one coat of clear
rlemn8r
Let's go to the river..
Ok, so because I'm a car painter I have to ask. When you guys cap these hulls front and rear and you respray the white gel and other colors associated with it, I assume you spray clear gel over top of everything you just did. Are you just blending the clear gel over the original gel and then rub it out to make it look unrepaired?? Just curious..
AZMIDLYF
This checks all the boxes for me. What is the weight of a standard layup hull? Guess we will find out what this will tally.
Gelcoater
In the case of white, no.
Not usually clear. It shines just fine without it.
The real issue is our clears are not a true clear like you’d be used to.
Over White it will give a bit of a yellow or brownish tint.
There’s absolutely clear over the carbon.
rlemn8r
Thanks Gelcoater. Makes perfect sense...
lavey jr
The carbon being layed into the mold looks a bit blue and out of the mold it has a little blue shade to it. Did you guys use a special type of resin for the carbon inlay or does that carbon have a little bit of a blue shading to it?
This is badass!!
K just looked at that Fountain Racing Engines FB page.... Is this getting one of there 1100+ hp LS9's? If so.... Everybody else is the single engine cat class just give up. Lol!
River Lynchmob
What can I do to u for u?
This is badass!!
Great looking boat but I'm pretty sure that DCB 28 with the 1350/1550 will have something to say about it.
Maybe. But this one will have the LS small block if it's that motor. Substantially less weight.
And it has substantially less HP.
Don't know how much HP that engine they are putting in will have. I was going off the only hp rating I saw on their page. I wouldn't be surprised if the engine that goes in is over that by a good margin.
Reactions: PSI
AZMIDLYF
I'm sure the pic doesn't do that any justice. Very cool looking stuff guys!!
PSI
Hey bud, all I can say is stay tuned, its gonna be real fun and a serious head turner!
AZMIDLYF
Ooooh, a built LS making noise in this beauty. :D
AZMIDLYF
The LS in this is getting a roots blower on it...:D
Where’s the thread on the tennis ball yellow walk off Speedster?
HCP3
Wow. Looks great. Simple scheme with tons of detail. That thing is going to scream with all the weight savings of the carbon kevlar and aluminum small block.
82daytona
Amazing! [emoji7][emoji7][emoji7]
