2FORCEFULL
- Jan 26, 2008
- 28,968
- 17,605
Here you go, I'm 10 weeks into this project, started out with a hammer and demo'ed all the walls, had to cut the slab and move the plumbing to the new island...
Wouldn’t picking up the game of golf be easier?
[emoji1]
fuc golf...Wouldn’t picking up the game of golf be easier?
[emoji1]
thanks buddy....the industry is making me work a lot...they want all the money, then they don't show up...Looks great. I'm truly amazed at the amount of work you do yourself. My hats off to you.
how can you see the insulation??? and it has 5 service vents....Looking at the insulation. Does that room get hot.
about like this, hey Jerry are you gonna come work on this pool or did you quit..answer, I'm gonna be there tomorrow and knock out a bunch... 2 days latter,... hey Jerry, did you quit... answer, I'm gonna be there tomorrow.......looks great! hows the pool coming along
Several of your pictures show the drywall removed. In one there is a canned light. Insulation should be flush with the drywall, in contact with it. Fiberglass insulation should have 6 sided contact in an air tight container. It never gets installed that way.how can you see the insulation??? and it has 5 service vents....
I had 16" sprayed over the top of the batts.... looks like snowSeveral of your pictures show the drywall removed. In one there is a canned light. Insulation should be flush with the drywall, in contact with it. Fiberglass insulation should have 6 sided contact in an air tight container. It never gets installed that way.
Attic roof vents do little to help keep the house cool. The roof gets hot and gives off most of it's heat via radiant heat. Off all the insulation fiberglass is the least effective at stopping radiant heat. Fiberglass is more air pourus thus is more affected by air leaks and in the case of an attic the top being exposed. Another factor is thermal bridging. Wood has an r vaule of about 1 per inch. This reduces the effectiveness of the as installed insulation by 15-25%. Fiberglass not covered on the top and other installation errors reduces it more.
A little on radiant heat. All objects give off radiant heat. That is how thermal cameras see. The more radiant heat given off by walls and ceilings the warmer you feel at the same air temp, say 70% . A well insulated house will have surface temps closer to air temp and will be more comfortable.
Think of the differences between winter and summer in the same house at the same temp. Summer you have shorts and a fan. Winter warm clothes.
Radiant temps are a big reason second floors are so warm in the summer compared to the first floor.
Air leaks play into it to. In the summer we cool the air in the house, shrinking it. Warm air rises but cool air sinks. Thus when you cool in air in the home it sinks and pulls in warm air from the attic. Air that is warmer than out side. Plus it may be more humid. Air sealing between the attic and the house is so critical.
Can lights are a big air leak and have lower insulation around.
Cathedral ceilings are under insulated. If there is a way I would try ad cellulose over the top.
That's good. I like cellulose better though.I had 16" sprayed over the top of the batts.... looks like snow
I'm pretty anal about insulation...here's one of my builds...That's good. I like cellulose better though.
I always wondered how it would do if you used Styrofoam that was the thickness of the studs.I'm pretty anal about insulation...here's one of my builds...
A good method of insulation is to put rigid insulation on the outside of the studs. A 2x4 wall is an r13 less the thermal bridging. Since a wall is about 25% framing thermal bridging reduces whole wall r value to 10.5 % or less. Putting rigid insulation on the outside of the studs stops the thermal bridging and has other benefits. How much insulation outside the studs is location dependent. Greenbuildingadvisors.com and building science Corp are good places to learn about energy efficiency.I always wondered how it would do if you used Styrofoam that was the thickness of the studs.
Sent from my SM-G900T using Tapatalk
Thanks. Would have never thought the studs would have that much effect. I know log cabins have pretty good insulation based on the size of the logs.A good method of insulation is to put rigid insulation on the outside of the studs. A 2x4 wall is an r13 less the thermal bridging. Since a wall is about 25% framing thermal bridging reduces whole wall r value to 10.5 % or less. Putting rigid insulation on the outside of the studs stops the thermal bridging and has other benefits. How much insulation outside the studs is location dependent. Greenbuildingadvisors.com and building science Corp are good places to learn about energy efficiency.
