beerrun
- May 25, 2010
- 4,285
- 7,759
Anyone have one? Please tell the good bad and ugly? If you could go back would you buy that motor again or go with a 5.3 or 6.2
Are you using alot ou oil? Like 1 quart per 1000 miles?Been great so far. No complaints. If buying new, just make sure oil is filled to correct level and you don't have a bad cam position sensor.......
This was from Temecula to OC
I'm reading that they are using oilI only have 1200 miles on it so far
So what is the story? Did your tahoe break already?Been great so far. No complaints. If buying new, just make sure oil is filled to correct level and you don't have a bad cam position sensor.......
Have the 3.0 love it. Came from the 6.2. Won’t go back. I tow a 24 ft enclosed and the magic from storage to the ramp 0 issues. I’m lifted on 35s also. Last week didn’t calculate my weight right picking up new catalogs ended up loading it down to about 13k lbs I know stupid mistake. Towed it back to the shop stopped etc no issues.
How many miles o your truck? Are you using alot of oil like a quart every 500-1000 miles? DEF use high?Have the 3.0 love it. Came from the 6.2. Won’t go back. I tow a 24 ft enclosed and the magic from storage to the ramp 0 issues. I’m lifted on 35s also. Last week didn’t calculate my weight right picking up new catalogs ended up loading it down to about 13k lbs I know stupid mistake. Towed it back to the shop stopped etc no issues.
I have 22k on it. It’s a 2021. No issues burning oil. But it does drink def every 3k miles or soHow many miles o your truck? Are you using alot of oil like a quart every 500-1000 miles? DEF use high?
Good looking truck. Did you have the fender flares color matched or did they come white?Have the 3.0 love it. Came from the 6.2. Won’t go back. I tow a 24 ft enclosed and the magic from storage to the ramp 0 issues. I’m lifted on 35s also. Last week didn’t calculate my weight right picking up new catalogs ended up loading it down to about 13k lbs I know stupid mistake. Towed it back to the shop stopped etc no issues.
Mine came white.Good looking truck. Did you have the fender flares color matched or did they come white?
That interval was 150k and on the newer LZO is 200k. Most likely by that point it’s about time for a trans rebuild anyway.Due your research… There is a pump in the Transmission, that has to have a belt replaced. Pending the year you have, its scheduled maintenance at 100K or 150K miles.
So, you have to pull the tranny to replace the belt.
THATS THE REASON, I WOULD NOT EVEN CONSIDER A 3.0 Duramax. Imagine what thats going to cost at $200/hour of shop time.
Not sure why there are so many guys passing on the 3.0 duramax just because of the oil pump belt.
Gm increased the change interval to 200k and the cost my friend just paid in Temecula to do it was $1350, parts were just under 300 bucks.
I also feel like most people here seem to be replacing vehicles before 150k-200k mile mark anyways.
Hell in perspective that's cheaper then a set of wheels or tires that most have no complaints about buying when they want to switch it up on their trucks.
I can agree on all your points i myself got rid of my heavily enjoyed lmm that had a major efi live / mike L “diet”and was a blast to drive let her go at 285k and ended up in a temporary at the time 02 2500hd 8.1 truck with 100k.Truck, Not me, 250,000miles minimum.
Unless my needs change, which just happened. Sold my 2002 GMC DMax 2500 with 265,000 miles ish, it towed my offshore 12000lb boat Several years ago.
Bought a 2021 Chev 1500 4x4, because its was enough to tow my lake boat, and didnt think I would ever need to tow more than 7500lbs
Sold a 2021 Chev 1500 4x4 with a. 5.3L with 29,300 flawless miles.
Replaced it with a 2016 GMC 2500 6.6L 4x4 thats fully deleted, and pretty modded.. Its one bad beast, custom CP pump, lift pump, exhaust, fully deleted, with a ton of other towing mods.
The only reason why I sold one for the other… decided I wanted to buy a toyhauler. So, I needed a 2500…
If not for that, I would have ran the 2021 for a very long time.
Regarding the 3.0 DMax, even with a 200k mile maintenance interval, I still wouldnt buy it. Why, because if you decide to sell it with 150k miles, thats going to be a detractor for the people who are looking to buy it, meaning reduces in market value and more importantly demand.
The 5.3 is a better choice. It doesnt have DEF fluid, or pre catalytic convertors, or ________________, extra systems that can fail. The 5.3 does have known issues, but those if they surface should surface while the unit is still under warranty.
Pros of the 3.0, better fuel economy, but higher fuel costs, and DEF, and more systems that have potential failures.
Pros of the 5.3, roughly the same hp/tq of the 3.0, less systems that can fail, pretty damn reliable, but can have lifter problems. But I outlined that problem above. If you have it, it typically surfaces when the car is under warranty.
Again, all of this is my opinion/needs, everyone is entitled to theirs.
Service is at 150k. As ridiculous as it sounds......the labor hours to remove and replace the trans to do the timing belt is less than to disassemble the front of the motor to do a timing belt.Due your research… There is a pump in the Transmission, that has to have a belt replaced. Pending the year you have, its scheduled maintenance at 100K or 150K miles.
Sounds like they raped him good for a few wires going to his DEF tank......jesusGuy at work has a 21 Silverado with the 3.0 and loves it except for the other day - he was driving home on the freeway and all of a sudden it went into limp mode, 5mph and his DEF light and a message came on that said DEF Fault and 5mph enabled. How can this be safe? He had it towed to the dealer and $1500 later he found out his dog had chewed through a harness under his truck. $1500 for a 12” harness. Without all the smog BS I’m sure it’s a great engine, but the emissions just make these diesels too unreliable for me.
Right? The scheduled replacement of the oil pump belt is the least of the worries..........$1200 - $1500 to change the oil pump belt is nothing on a diesel - I came from an LML Duramax and every service was at least $1000 after 100k miles. Once this engine is out of warranty and maintenance Items start coming into play there will be sticker shock amongst all these first time diesel onwners.
Or make sure your dog don't eat F'ing wires...Sounds like they raped him good for a few wires going to his DEF tank......jesus
Sometimes you chock it up as a lessoned learned.My 4Runner is also unreliable. A rodent ate through 5 of the 6 the fuel injector wires once.
