Your ad here
- Oct 16, 2014
- 4,634
- 7,464
Need some help on trying to figure out an ammeter for a 3 phase electric motor. Motor is a Baldor EM2334T 20hp electric motor. 3 phase wired for 480 volts and rated at 24 amps. There is an analog Simpson ammeter with transformer installed now. 0-150 is the range. Question is, should the load on the motor max out at 24 amps per the meter? Or 48 amps per the meter since its monitoring one input leg? I'll describe the wiring as best as I can. Powered by a 36kva generator. There are 3 "hot" lines going into the magnetic switch and there is also a ground wire with nothing spliced into it. Just a dedicated ground.
