300XS Hesitation Question
toto
Howdy Churchgoers - I have noticed a hesitation out of the hole with my 300XS. When I give it gas is feels like it goes into limp mode or something for about a second or two and then is fine. Is this normal or what should I check - coil, injectors. Thanks
Ragged Edge
Man in the Box
I had the same issue with mine back in May. Talked with Joe at Hot Laps and he advised to replace the MAP sensor, he was right, problem solved.
854445 MAP Sensor - Mercury Marine | Crowley Marine
