30amp with 2 ac’s
bldrinker
Anyone have first have experience with 30amp service with 2 ac’s.
I’m trying to talk my wife out of a 40’ 3slide jobber in favor of a momentum 28g. But they only sell the momentum bumper pull with 30amp even with the second ac.
I’m scared this will be an issue.
shit I may have even asked ya’ll this. I’m going crazy trying to find the right unit.
Uncle Dave
Unless you are talking about something less than a 13.5 - It will most likely be an issue without soft start kits for sure, the hot restart is the killer load, you get 2 of those happening concurrently you'll pop a 30 amp breaker.
bldrinker
It will be an issue without soft start kits for sure.
Supposedly they have acs with soft starts and somehow it automatically drops load so the breaker don’t trip.
I’m reading that I might get away with both ac’s being in but not even the fridge can be on electric.
60k for a trailer and I have to pick and choose what I run sucks.
dirtslinger2
I can run my 2 AC's on 30amps. I have one those "things" on my control panel and tell the coach how many amps I have coming in. Only time I've had issues is at Big Bend where their power is a little janky, and I trip their 30amp breaker repeatedly Anywhere else I haven't had any issues running on 30amp service..
Done-it-again
Should be good as the fridge will be on propane and will not be running on electric when running the gen.
You might not be able to use both airs and the mirco though.
Singleton
I run 2 13.5AC’s on 30amp. I added the softstarts to reduce risks
Not issues
Singleton
What else can you run with both ac’s going?
when running on the gen (5500 EFI), I turn the front AC off when we run the microwave. Besides that, never been an issue. To be honest most summer camping we are wired in, and use gen when traveling point A to B and usually only run rear AC when eating lunch. Very limited boondocking in summer.
when plugged into a site for an extended period of time, I run the refrig and feeezer off electric and have that wired to plug directly into 20amp breaker on pedestal. Don’t worry about microwave when plugged into pedestal. I also have an EMS on the trailer.
Only time I pull close to 30amp is when everything is running through trailer and microwave cycles up and wife hits the microwave at same time
LazyLavey
No issues running a 1350s on 30amp
This little EMS thingy here monitors current and will redirect power while running 2 a/c on 30amp...
It will temp shut down compressor on 1 a/c if I use the micro and so on...
JB in so cal
was this something you had installed after purchase of installed at manufacturer?
Rbcconst
You can upgrade the panel to a 50amp. Not sure what todays pricing is.
A 28ft trailer will seldom need both AC's running.
I had a Winnebago on 30 amp
ran both airs and a microwave they have something in the wiring…. When we turn on micro it would shut of ac compressor on one unit
i had an Intellitec deal same as post 10
LazyLavey
Mfg installed....
I'd check what the cost would be to have a EMS installed... may be worth it
Another option, if you're handy at electrical (or have a "guy") is to rewire one a/c to bypass the coach and run that a/c directly into the 20a plug on the campground pedestal.
I installed a second a/c on my SILs 5er. replaced the bedroom vent with an a/c and it plugs directly into a 20 amp with an extension cord. Completely bypassing the coach electronics. like Bpracing did.. won't work when dry camping and using a genny unless you can switch over to run all on genny
I considered converting to 50A but anything I read looks fairly complicated and not worth it for me.. I have a simple mind
Icky
If you camp and its much over 100 degrees youll need both.
I agree, my 28 weekend warrior needed both running to keep it comfortable past 100ish. And I'm thinking about adding a 3rd to my 40 genesis for those 110+ days
Rbcconst
We had a weekend warrior 3705, 2 roof top ac’s and added a portable ac ducted out of the fresh air vent that was low on the wall.
ArizonaKevin
Reading this is real interesting to me, I have always been under the impression that with 30amp you are stuck at 1 AC unit. We were at havasu landing the other weekend and were struggling with our 30ft rv with just one unit.
Those of you that have added a unit to your 30amp setup, ballpark cost?
Icky
I will add the 3rd to the rear vent and just run an extension cord to the park power. It will be out of the way on the roof, and I don't need it anywhere else but the river.
Uncle Dave
just for snicks whats the brand of 13.5's ? Is it coleman or dometic?
I want to look up the running amp draw and see where it is according to the manufacturer.
yz450mm
For reference, I can run all 3 ac units on the 5500 generator no problem, as long as the electric hot water heater element is off. I think you would be fine, just remember to kick one of the AC compressors off before using the microwave.
An inline surge protector/voltage monitor is always a good idea, especially if you're going to be pulling a bunch of power from the park supply.
Amazon.com: Camco 50 Amp RV Power Defender Voltage Protector/Monitor with Integrated Surge Protection, Designed with Easy to Use PowerGrip Handles (55306): Automotive
STV_Keith
My RV has two 15k A/C's. When ambient temp was under 100, I could run them both off a 30a circuit here at the house. I generally set one 2-3 degrees different from the other, so they don't try to start at the same time. Since it's been over 100, I've popped the 30a once or twice. Bought this Camco "Maximizer" and ran an extension cord from the house (different circuit) to make up the difference. No problems since.
SpectraPat
Waffles
My 30a system runs both of my units through the intellitec system.
I took this screenshot a while back because I wanted to see what the amperage pull was when we ran 1 ac unit down the road and this is what I got. Mind you, fridge was set to AC, living room A/C was on High and we had 2 tower fans going at the same time.
I’ve also retrofitted a portable standalone unit to run and exhaust out of the passenger side window for those days that hit triple digits
Waffles
I’ve been meaning to do this mod but I got way too lazy before the season started and the heat ramped up. My current setup is working pretty well so I’ll probably tackle this towards the end of the year
Singleton
very similar to what I did for my 3rd AC.
RCDave
Ive run both my 15k units off 30 amp. They key is to make sure the batteries are fully charged, inverter is off, passengers keep lights an other 12v accessories to a minimum. And turn the temp control below where they will shut off and cycle. I've metered mine at 12 to 13 amps steady state
HB2Havasu
You should see if Momentum can put in a 50amp panel in the 28’er with (2) 15K BTU A/C’s. I’m guessing they’re running (2) 13.5K BTU A/C’s off of (1) 30 Amp Breaker? That’s fine up to about 95F. When you go north of that it’s going to be hot af in there! J/S
Riverryder
Is this a new momentum with 30amp?
I pick my new reflection next week that’s 50 amp. Thought they all came 50 amp now
We run two AC's, a refer and two TVs in our old 36'er, but we're also on a 50 amp. Another thing to consider would be the insulation in the RV. Our old faithful gets so cold that we have to turn down the AC units to keep comfortable. We are in Parker, with little to no shade nearby. We have a generator but have never had to use it. 🤷‍♂️
bldrinker
It’s how they build the 28G. I don’t think they even give a 50amp option.
ka0tyk
I don’t get why trailers and rvs don’t just do 50 amp. The cost is almost nothing in comparison between the two. I can run both our furrion 15.5s off one 30a leg of our generator no issues. But that’s just the acs. No cooktop no fridge etc. we also have soft starts. If you were gonna do it I’d set the temp to 60 so they aren’t clicking on/off the whole time. That’s the killer if they both try to start up at the same time.
Jesus! Here's a $12 part that accomplishes about the same thing.....
