496HO compression test numbers?
CAZ007
Looking at a used boat with a 2008 496HO, 170 hrs. Compression test showed 175psi, I’m assuming across the board but will follow up to see what each cylinder read. What is the normal range/spec for these motors?
Thanks in advance!
CAZ007
Got the numbers they all range between 170-180.
