TripleB
- May 27, 2017
- 1,536
- 2,463
1968 Ford 289 SOHC V8
Ford built three experimental 289 with a unique single overhead camshaft design that features a cam located in each of the cast aluminum valve covers (instead of on top of the cylinder heads). The lobes of each cam activate the cast iron rocker arms that open each valve. In the original camshaft position within the engine is smooth shaft whose role is to drive the distributor as well as the two overhead cams. The purpose of this project was to raise the maximum engine speed and with it peak power. The OHC 289 produced 300 HP at 6500 rpm.
