BUSTI
- Mar 24, 2010
- 2,009
- 795
SOLD! 509 Big Block Chevrolet built by Pfaff Racing Engines. Roughly 35 hours run time after build. Engine was broken in on the Dyno and then tuned on the Dyno. Dyno sheet provided.
Engine made 577.4 ft-lbs @ 4,400 RPM and 563.6 HP @ 5,693 RPM.
Engine was built with lower compression as I was planning on installing a Blower or Whipple at a later date. Now my projects are going in a different direction.
?GEN V 8.2/502 Block, 0.030? over bore
?8.6:1 JE 4.500? pistons
?6.135? Manley H-beam rods
?4.00? stroke GEN V 502 GM forged crankshaft
?Mellings high volume oil pump
?Dooley 10 quart V-drive oil pan
?Clevite bearings
?JE piston rings
?320cc Merlin rectangle port cylinder heads
?Cloyes billet timing chain
?Crane hydraulic roller camshaft
?4130 Manley pushrods
?Competition CAMs gold roller rockers
?Polished single plane intake manifold
??? JOMAR carb spacer
?850 Holley double pumper
?Stainless steel flame arrestor
?MSD marine distributor
?1? Magnaflow CAM driven water pump
?GM balancer
?GM steel flywheel
?IMCO GEN V timing cover with water pump drive
Note: Exhaust not included
Price $6,800 OBO
Call or PM me with any questions. 714-588-7086
?Clevite bearings
?JE piston rings
- 118cc combustion chambers
- Pocket port
- Bowl blend
- 2.300? Stainless steel intake valves
- 1.88? Inconel exhaust valves
- Grind number HR230: 230* duration int. / 236* duration exh. / 114* lobe separation / .598? lift int. / .610? lift exh.
?GM balancer
?GM steel flywheel
Price $6,800 OBO
