[WTS] 598 long block
boatguy222
Dart block, Scat rotating assemble, Comp hydraulic roller, Armondo's 10 oil pan for v-drive. ATI dampener, aluminum flywheel. Short block is all new parts. 10 to 1 cr pump gas engine.
Heads are iron Merlin VR, they are fresh, roller rockers and. B&M 2 piece valve covers. MSD M-6 with MSD distributor. Bolt on your intake and carb and go! $6500 located in Castaic Ca.
Marc 541-968-6760.
boatguy222
Merlin VR Heads have 345 intake runners intake valves are 2.30, exhaust are 1.90. I believe they have Crane roller rockers.
The cam we have a custom design from Comp, I don't have the exact spects for it. The engine is being assembled 900 mile away. Around .620 lift, and just under 300° duration.
I will get the exact spects as soon as the engine guy gets back to me.
boatguy222
The cam spects are:
236@50 int. 244@50 ex. 613lift in. 647lift ex. 112 lobe sep. Adv dur. In 291. Adv. ex 299
Profiled by Grubb, ground by Comp.
Damn....... this long block with the intake and efi set up Hardcore is selling would be bad assssssssss.
boatguy222
John said it is still a short block.
I would take 6k cash for it.
boatguy222
Ok, low ballers please don't waste my time. Just to be clear, I have over 6K in the short block alone. I have NO DESIRE to give It away.
Thanks
aaronschiada
Thanks
Low baller? I made you an offer. I don’t need the motor either, I also know how hard it is to sell a motor private party. I sold a brand new 850HP 509ci blower motor last year for $10k...I had over double that into it. I think $5k is a very reasonable offer considering I can buy a brand new 598 short block from CNC Performance for $5200. https://www.cnc-motorsports.com/cnc...t-block-scat-crank-diamond-103-1-pistons.html
Good luck with the sale!
