5th Wheel Slide Out Question
Discussion in 'Trailers' started by t&y, Aug 20, 2019.
  1. t&y
    t&y Well-Known Member
    10,201
    10,423
    Jan 9, 2010
    2011 Heartland Sundance 3300CK model with the rear bunk house.
    Rear slide came in real slow last time and now it won't go out. Is there something other than replacing the motor that could be an issue here? I also noticed my rear leveling jacks were real slow to extend which makes me wonder if it's a power issue to the rear of the trailer, or something else.
    Anybody have any idea's?
    I have an appointment at Richardsons Family RV in Riverside next week, just looking for other opinions or shop recommendation prior to dropping this thing off.
    I have ZERO clue when it comes to electrical work so I'm kinda out of luck there.
  2. NicPaus
    NicPaus Well-Known Member
    8,157
    4,445
    Sep 15, 2010
    Can you check the power at the slide motor? Put a booster on the battery to rule bad battery out.
    t&y and Deja_Vu like this.
  3. Deja_Vu
    Deja_Vu Essex Affectionado
    6,061
    4,486
    Aug 4, 2014
    Sounds like a battery to me also. Start there.
    t&y likes this.
  4. t&y
    10,201
    10,423
    Jan 9, 2010
    It's hooked to the house. Everything works fine accept the rear slider and rear landing gear. I'm crossing my fingers it's something easy electrical. Fuses are all good.
  5. NicPaus
    8,157
    4,445
    Sep 15, 2010
    Are the slide motors 12V or 110?
    t&y and Kachina26 like this.
  6. HitIt
    HitIt Well-Known Member
    1,432
    1,746
    Apr 29, 2008
    Have you done any battery swaps recently? Had a friend that went from 2x12V to 2x6V and only wired his jacks to 1 6v battery. I stood by him drinking a beer and heckling him while we waited for a few minutes for his trailer to get leveled before I told him what the problem was.
    also, even when my batteries are pretty full, my 12v jack seems to run slow. I am good to go when fresh off charger or while charging.
    t&y likes this.
  7. Ballsdeep
    Ballsdeep Well-Known Member
    5,374
    4,211
    Feb 25, 2009
    Maybe a bad or lose shared ground wire?
    t&y likes this.
  8. t&y
    10,201
    10,423
    Jan 9, 2010
    I'm completely retarded when it comes to electrical anything. I've used it hooked to the house plenty in the past with zero issues. This is the only time it's started doing this. I also noticed my rear landing gear is moving real slow. I agree, it's almost as if it's running off of a real low battery, but the battery is fully charged, and it's hooked to the house.
    Good thought, no new battery.
    I'm hoping this is all it is.
    The trailer is used but has been very well taken care of. The bottom is lined with sheets of thin cardboard or something similar so everything is hidden. I'm hoping something just cam lose in the short trips I've taken it on.
    Ballsdeep likes this.
  9. Ballsdeep
    5,374
    4,211
    Feb 25, 2009
    Check all wires, I had a new toy hauler and they put flooring over the wire so over time the floor rubbed the coating off the wire and was grounding out.
  10. yz450mm
    yz450mm Well-Known Member
    1,814
    2,070
    Jun 10, 2013
    A battery can show good voltage on a meter,but have a bad cell, which kills the output under load. Load test or replace the battery, and clean the cable to terminal connections while you're at it.
    Sent from my SM-G975U using Tapatalk
    DRYHEAT and Kachina26 like this.
  11. thmterry
    thmterry Well-Known Member
    1,393
    820
    Jul 29, 2011
    Being plugged in doesn't matter to 12 volt motors. I would test batteries individually. I just had a slide that would not work plugged in but worked with new battery.
    Kachina26 and NicPaus like this.
  12. MagicMan
    MagicMan Well-Known Member
    90
    84
    Apr 19, 2019
    Can u swap with your vehicle battery to troubleshoot?
  13. HitIt
    1,432
    1,746
    Apr 29, 2008
    When plugged in, the converter is usually charging the batteries and is good for 50 - 100amps and holds them well over 13V. It could easily make a difference.
  14. thmterry
    1,393
    820
    Jul 29, 2011
    You can put all the juice you want into a bad battery and it still wont work.
    Icky likes this.
  15. River Runnin
    River Runnin Well-Known Member
    2,560
    2,419
    Jun 17, 2008
    I have 2 slides that are electric, and 2 Hydraulic...... Both batteries are 6 Volt!
  16. HitIt
    1,432
    1,746
    Apr 29, 2008
    Well, not after you remove the converter. But the converter isn't electrically isolated from the load side of the battery so it could basically power the 12v rail of the coach even if the battery is dead. All I am saying is that the 12v motors for the jacks and slides could work fine when plugged in and getting juice from the converter even with a dead battery.
  17. thmterry
    1,393
    820
    Jul 29, 2011
    Didnt work on mine, put a new battery in and everything worked fine.
Share This Page
