Blackmagic94
- Apr 4, 2017
- 5,270
- 7,240
Locked out timing or Mech Advanced.
468 bbc
6-71
-17% under driven
468 bbc
6-71
-17% under driven
Do you have a hard start condition when the engine is hot with that much initial in it?I have blowershop 250's on a 460 and 468 with Merc TBIV distributors and V6-14 ignition modules. These modules on a v8 give around 7-8 total advance and all in by 2500rpm. My Idle is at 28 degrees and all in with 35 degrees.
Same size motor with different blower size but i'm pretty sure this would work with yours too if you find yourself going this route.
not at all, engines hot or sitting at cove all day, turn the key and they fire right up. Now sitting for a few days is a different story but that's a fuel topic not timing.Do you have a hard start condition when the engine is hot with that much initial in it?
You're going to run a roots blower with no intercooler, iron heads, and 9.2:1 compression on california pump fuel? I dont think there is a safe setting I can recommend to be honest. Keep it to 4 PSI boost and 30 degrees. Just lock it out at that point, or run the shortest/fastest curve you can, whatever is easier.
JT
JT
Definitely needs an intercoolerYou're going to run a roots blower with no intercooler, iron heads, and 9.2:1 compression on california pump fuel? I dont think there is a safe setting I can recommend to be honest. Keep it to 4 PSI boost and 30 degrees. Just lock it out at that point, or run the shortest/fastest curve you can, whatever is easier.
JT
Leave the advance in the distributor. Use the black bushing (largest in size least amount of advance) and the lightest springs. you want full advance as soon as you can with teh roots blower. Set the total timing at 32* - 34* total timing. Locked out Distributors IMO put unnecessary wear on the starter.
Black p
Bushing is in it already. Would it be safer to start at 30 total or is that gonna build more EGTs
Yep, unburned fuel leaving through exhaust valve. Sounds counterintuitive but it is what it isI’ve read that to far retarded makes it run hotter.
View attachment 839843 JegS billet mechical advance with 4 curves or locked out
Msd marine 3 digital
Msd coil
Lock it out
9.2;1 compression
91 octane
Dual 650xp Holles
Hydro roller cam unknown
the jet boat is what this is going on.
No!Boost bottle?
So you got 34 different answers and opinions. Call a reputable motor builder and ask the people that do it all day everyday. Teague jr. comes to mind. That'll be your best answer.
Do you want power or do you want it to live?
Boost gauge
Electro fuel pressure gauge
Ngk plugs 1-2 steps colder at 0.35 gap from what I was running
Start at 28 total and adjust from there
Still need help on base jetting and such
Cause slapping a roots on top of an existing bote motor is easyIf your familiar with turbos why not go that route?
