8
Discussion in 'The Outboard Church' started by kellytheaker, Sep 22, 2019.
  1. kellytheaker
    kellytheaker New Member
    4
    Jul 23, 2019
  2. zx14
    zx14 Well-Known Member
    2,000
    2,219
    May 4, 2010
    Wow, never seen a bracket from inside the boat. Interesting.
  3. zx14
    2,000
    2,219
    May 4, 2010
    If it where me, I’d adios that bracket, install the aluminum knee braces inside the boat/transom, put a conventional Dana or whoever’s bracket on it with as much setback that is needed to clear your steering. I had like 10+” on my 21’, I would assume the 19’ doesn’t need much.
    DRYHEAT likes this.
  4. Flying_Lavey
    Flying_Lavey Dreaming of the lake
    14,628
    8,470
    Feb 13, 2008
    My .02......
    Notching the center pod really won't do anything for the boat as these older Daytona's (I believe) all had the same same depth sponsons so you notch the center, the boat is then still riding on the outers at the same proximity to the engine.
    I'd ditch the bracket as well. I know it's likely original to the boat, but based on it's design, it's not helping you much. The fact that it's on such a negative angle and so close to the hull shows they were trying to make-up for set-up issues by allowing the engine to tuck in further. However, it's so close, it doesn't look like a speedmaster style lower will ever be able to use that amount of tuck.
    I'd ditch that plate, put in bracing inside to the stringers, and mount a standard 10" hydraulic backplate. Done.
    zx14 likes this.
  5. Flying_Lavey
    14,628
    8,470
    Feb 13, 2008
    [/QUOTE]Yes, the bracket would need some negative angle to it due to the 19 having a vertical transom. I do believe many of the set-back jack plates include certain amounts of negative angle or can be ordered with it. That is a hell of a lot of negative angle on that bracket there. I'd call one of the well known outboard shops and ask them what they suggest for the angle. A 19 Daytona shouldn't need much down trim.
  6. kellytheaker
    4
    Jul 23, 2019
    Thanks
Share This Page
