97 454 MAG sea/Raw water pump bracket HELP!
TheGuilty1
New Member
I need help!! I had my engine built and in the process my sea pump bracket has disappeared some where. I need to find a replacement with the idler and everything for it or need to know if I can switch to the newer billet bracket and ditch the cast bracket and idler setup. The first picture is what was on the motor and I'm wondering if the second one would work or if someone has the original one sitting on a shelf somewhere. Any help would be great.
Nates270
if your current raw water pump has the fuel pump provisions on it then the custom bracket wont work. cp performance also states that this bracket doesnt work if youre using a circulating pump. hope you can find the one you're needing.
Lavey 29
If I stand corrected the bracket in the pic from CP - it possible might not work if you are using the water circ pump. If I remember correctly its can be used if you are using the crossover instead of the water circ pump. Maybe look at that bracket closer how your front of the engine is set up
