- Sep 13, 2007
- 123,373
- 151,201
Before pics.. Trailer was delivered and the tires were rubbing on the fenders, as well as the strap was rubbing and fraying already..
Caskets are the recessed stainless pieces the long LED lights are installed in. I switched mine to black and the adrenaline style ones instead of the extreme ones. They just have an angled edge instead of round.Caskets Bunks
Got a pic of that blue trailer submerged
What is the purpose of the bolt holes drilled down thru the frame rails?
What’d you do with the extreme caskets? I’ll buy them from you.Caskets are the recessed stainless pieces the long LED lights are installed in. I switched mine to black and the adrenaline style ones instead of the extreme ones. They just have an angled edge instead of round.
That’s where they installed the up lights.
X2 how did they fix that!?The bling and lights are nice and all.. but the important question.. do the tires still rub?
Since they are LED lights can you control the color of the lights via app on your phone? I know they are doing that on interior lights these days. @RiverDave
Why were the tires rubbing?
damage, i need two but would buy more, if you happen to get them.They are still down at adrenaline. I didn’t ask for them back.
Any idea why they use the Rigid vs the same 3/4” pop ins? I’ve been contemplating doing the 3/4” pop ins as under lights on my trailer.Adrenaline doesn’t offer them yet but if you went on superbrightleds.com you could order them to do that..
or get offroad rock lights like I did on my motorhome.. the under lights on this trailer are rigid rock lights, single color.
Do they seal all the holes drilled for the LED’s with caulking or grommets to prevent rust?
Ive been looking everywhere for my new build and he is correct. However they are no different than rock lights on a sxs so you can go that route. I just havent found any that look good enough to install in my boat yet. im actually thinking about strips currently...I don't believe they have found or make small RGB marine lights yet. I asked a couple weeks ago and they only have single color.
I don't believe they have found small RGB marine lights yet. I asked a couple weeks ago and they only have single color.
Your correct. We just went with Blue. I searched high and low for something similar in size and can get dunked.Ive been looking everywhere for my new build and he is correct. However they are no different than rock lights on a sxs so you can go that route. I just havent found any that look good enough to install in my boat yet. im actually thinking about strips currently...
How do you turn the colored lights on? I assume they aren’t on all the time when the running lights are on?
40$ each from extreme, I’m sure they’ve already made plans for them if you didn’t get back.just call them and tell them you need a couple of extreme caskets.. I am sure they are cheap? If not free?
RGB Rock lights. Work awesome I’ve not used on a boat trailer yet, but have used plenty on offroad stuff. They are fully sealed and IP65.Your correct. We just went with Blue. I searched high and low for something similar in size and can get dunked.
Use the center pin on your 7 way, which should be a constant hot, then run all your power and ground add a small round rocker like vvv, most do on the bottom of the top step of the front ladder.I was wondering the same. Are they on a switch? I am only curious because I really want to do this.
Nice rig big fella !!!Before pics.. Trailer was delivered and the tires were rubbing on the fenders, as well as the strap was rubbing and fraying already..
View attachment 989816 View attachment 989817 View attachment 989818
What lights did you go with on the bottom?
If you are doing a scratch build they make bunks now with the LED’s incorporated into them..
What's the wheel size and tire size on that? Looks good!
